Results 1 to 9 of 9
  1. Member yoda313's Avatar
    Jun 2004
    The Animus
    So I like everyone else here have tons of audio and video cables laying around. I also have lan cables and power strips and the like.
    What is a good way to store these neatly and efficiently?
    I'd like to try to keep them organized and kink free preferably. I don't really want to buy any furniture type appliance. If you have ideas like coiling them around somthing I'd appreciate it.
    Links are welcome too.
    USA
    These donut shaped organizers are popular. Just wind the cable around the center post and it stays put. http://www.cyberguys.com/templates/searchdetail.asp?productID=11210
    Or get lots and lots of wire ties.
    My cables always start out organized, but moving stuff around tends to ruin that fairly soon.
  3. Member Number Six's Avatar
    Mar 2008
    I fold my cables up neatly and secure them with a wire tie in the middle - I do not wind some of the wire around the folds because it holds the coil shape when it is unwrapped. I store them in a box in the closet where they are easily accessed.
    "I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
    (NO MAN IS JUST A NUMBER)
    be seeing you ( RIP Patrick McGoohan )
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Thanks for the ideas.
  5. Rolled up in zip-loc plastic bags.
  6. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    ^ seconded
  7. Member yoda313's Avatar
    Jun 2004
    The Animus
    @jagabo and supreme2k - that's not a bad idea either. Cheap and easy. PLus if you get the larger bags you can store more. Not to mention many have that little labeling area where you can put descriptions if you want. Though usually the shape of the plug is a big clue
    Sep 2006
    "Sterilite" clear plastic stackable containers with lid. Many different sizes avaliable. Look into container to see what's inside. You can also label them. BigLots! has the best prices. I've also purchased some from WalMart.
    http://www.sterilite.com/Category.html?Section=Storage&ProductCategory=39
    creakndale
  9. Greetings Supreme2k's Avatar
    Feb 2003
    Actually, I do the cables inside ziplok inside a sterilite to hold them all.
