If the original item (DVD player, etc.) has ONLY a composite out ... is it worth getting one of those $179 scaler/converters to hook up to DVI or HDMI or component?
Will there be a difference? Better than the RF input? Being that the source is composite?
Thank you.
It would be cheaper to buy a new DVD player that has HDMI/Component Video Out. Costco has the Philips for $39 I think.
I would think the HDMI/Component output from a converter would look worse than the original composite input.
For $179US you could purchase several low cost DVD players with HDMI or Component output.
Usually the best display quality is HDMI/DVI as it's a digital format, then analog Component, S-Video, Composite and lastly RF, though RF may be slightly better than composite, depending on the setup. Some displays also accept VGA, which is also analog. I would guess VGA may be close to Component quality or a bit better. A lot has to do with the conversion quality and the settings used. Since a computer and a DVD player are both digital devices, the digital signals are subject to less conversion losses. JMO. -
Or look into the new Toshiba upscaling player which many people are raving about:Originally Posted by redwudz
http://www.amazon.com/Toshiba-XD-E500-Upconverting-Extended-Detail/dp/B001D9IWIY
https://forum.videohelp.com/topic355600.html
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
Connect VGA/DVI/HDMI source to Component HDTV
By jstewar9 in forum Media Center PC / MediaCentersReplies: 0Last Post: 13th Jan 2010, 16:11 -
HDMI to DVI conversion problem
By bmeagle in forum Newbie / General discussionsReplies: 1Last Post: 15th Nov 2008, 09:02 -
Audio problem in DVI to HDMI conversion
By sfurqan in forum ComputerReplies: 3Last Post: 23rd Jun 2008, 19:41 -
Philips DVP5960 HDCP Question /// HDMI -> DVI and Composite Audio?
By cactusPhone in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th May 2007, 23:32
