tried 3 different VCRs .. VHS tape, hear the audio , but picture all fuzzy /snow.. all cables correct of course, using composite cables, tried even connecting to TV and capture card.
Sounds like really bad tracking. You may only be able to fix it with a TBC. However if its too far gone you might not be able to recover it all...... (edit - at least on a prosumer level - perhaps an official restoring service MAY be able to for a price)
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
whats weird is it was playing fine yesterday on a VCR, i had to FF a bit and heard noise.. took out tape right away and noticed a bit was being chewed.. so then tried another VCR and it was tracking issue, it has digital tracking and wouldnt get it right.. so now tried the 3rd VCR and this is whats happening. you think getting a tape cleaner would do the trick then, if not professional.. k thanks
A tape cleaner wouldn't hurt. However I haven't done that stuff in quite awhile so I don't know products you should look into.
I'd save the professional stuff as a last resort. However it doesn't sound good if the tape was being eaten......Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
vhs tape wont play picture
By kitchensira in forum Newbie / General discussionsReplies: 22Last Post: 27th Jan 2018, 21:11 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Standalone recorder that doesn't stop recording in response to VHS snow?
By thx1138d2002 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Dec 2011, 23:55 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
How do I dub the sound on a VHS tape but keep the picture?
By jimbo7777 in forum AudioReplies: 1Last Post: 24th Jan 2010, 00:15
