Closed Thread
    Sep 2007
    I have encountered recording problems with DVD+RWs burned on my PC
    using its internal Ricoh DVD+RW MP5240A 1.11 recorder. If I burn a
    video DVD+RW and play it exclusively on my PC, I can later erase it
    and burn another video to it with no problem.
    However, if I play the recorded DVD+RW on another PC and then return
    it to the initial PC that burned it, it sits in the Ricoh recorder
    tray with operational lights flashing and locks up my PC and will not
    play or erase - when returned to the other PC it reacts in the say way
    and refuses to erase or play.
    Has anyone had a similar problem? It doesn't seem to matter which
    DVD+RW brand I use.
    Any suggestions or comments would be appreciated.
    Mary
    Please don't cross post. Once is enough. COntinue in https://forum.videohelp.com/topic358763.html
