So far I used bbMPEG for muxing without a problem, but there is always a little Note in the status window of bbMPEG saying "NOTE: Mux rate may be too low for data rate?", does one of you know what that means and how I fix it. I mean, the SVCDs work fine anyway, but who knows... maybe not always.
SiCN - the real one!
"Dudes, we gotta think here... What would Brian Boitano do?" -
This message is shown when the peak bitrate for video+audio is higher than what is allowed by SVCD spec. Fortunately there are buffers flattening the peaks over a short period of time, so you should worry only if you actually get buffer errors during multiplexing.
And if you do get buffer errors than you can set the forced mux rate to 0 which makes bbmpeg select the appropriate number for you.
avi data rate too high?
By hello2000 in forum Video ConversionReplies: 5Last Post: 3rd Aug 2010, 10:43 -
DV to h.264 for live streaming at low bit rate?
By VidQues in forum Video ConversionReplies: 1Last Post: 22nd Mar 2010, 07:56 -
Data rate for HD video
By spandau in forum EditingReplies: 3Last Post: 21st Nov 2007, 13:23 -
Intentional low frame rate?
By stationconfusion in forum EditingReplies: 3Last Post: 2nd Nov 2007, 14:20 -
What is program mux rate?
By supernano in forum Video ConversionReplies: 3Last Post: 1st Nov 2007, 07:40
