Results 1 to 25 of 25
  1. Thanks to PureBasic cross compiling i was able to tweak automen and porting to Linux
    AutoMen 6 is here (beta.. as usually)
    http://www.64k.it/andres/data/automen/automen6_x86.tar.gz
    tested on Fedora 32bit, Ubuntu 9.04 32 and 64bit
    need mencoder, mplayer, xterm
    BHH
    HDConvertToX, AutoMen, AutoMKV Developer
  2. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Looks just fine on Slackware with Xfce. Nice and easy GUI, and easy enough to comfigure profile.txt. Cool, and thanks
    Doesn't support directories with spaces in them. Threads option doesn't seem to work
    Prompts for mp4creator, but doesn't need this installed to run.
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
  3. thanks for your kind words!
    remember that xvid isn't multithreaed on mencoder... just mpeg4 and x264
    feel free to post any problems and suggestion
    (and i will look the "space" problem)
    thanks
    BHH
  4. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Xvid is multithreaded.
    xvidenc (-xvidencopts)
           There are three modes available: constant bitrate (CBR), fixed quantiz-
           er and two pass.
    snip
     The following option is only available in the 1.2.x version of Xvid.
           threads=<0-n>
                  Create n threads to run the motion estimation (default: 0).  The
                  maximum number of threads that can be used is the picture height
                  divided by 16.
    You can grab a multithread enabled xvid here - http://www.xvid.org/Downloads.43.0.html Just download the daily snap shot.
    The default in Ubuntu and other Debian based distros are not multithread enabled. Plus they have a habit of not using NASM, so it's even slower.
  5. and i don't provide mencoder builds.. so i must rely on user repository/packages
    you can tweak the profile and add the threads parameter
    BHH
  6. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    BHH
    Has nothing to do with mencoder. It's the version of Xvid that is installed. I'm using MEncoder 1.0rc2 which is quite old. Check your man page for mencoder.
    If you're using an old Xvid (1.1.2/.3) specifying threads=n does nothing to it.
    All the way back to mencoder 1.0rc1 (Ubuntu Fiesty 7.04)
    The following option is only available in the CVS version of XviD.
    threads=<0\-n>
    The maximum number of threads that can be used is the picture height
    divided by 16.
    But that's for xvid. I stated the threads switch doesn't work at all
    WIth x264, it always uses more than one core no matter if it is ticked or not. With lavc it only uses one core. This is because your profile.txt has threads=auto hard coded for x264, and negates the thread option for mpeg4.
  7. thanks disturbed1!
    learning is a never ending process!
    about threads disabled i will check when home
    thanks again!
    BHH
  8. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Perhaps, since x264, lavc, and xvid all use threads=$, that could be a variable that can be passed? But that seems like too much of a coding change. I don't know, I'm not a programmer. Considering your profiles.txt is easy to read and change, I'm just editing it by hand.
    I've been using your program to encode a few streams to xvid, lavc, and x264, and they all work!. Have to say I really do like it. This is a first for me, as I'm a command line junky.
    About the directory spaces. Read from spaces, write to no spaces works. Read from no spaces, write to spaces works. Read + write to spaces, doesn't work I even did a chmod 777 on the directory so everyone has rw on it just to make sure.
    "/usr/bin/mencoder"  -ofps 30000/1001 -vf harddup,crop=720:480:0:0,scale=656:-2,hqdn3d -sws 2 -o "/home/keith/a directory with spaces/test_automen.avi" -ovc xvid -xvidencopts bitrate=1682:max_bframes=2:bquant_ratio=162:bquant_offset=100:vhq=1:me_quality=6:chroma_me:nochroma_opt:hq_ac:notrellis:lumi_mask:autoaspect:bvhq=1 -af volnorm=1  -oac mp3lame -lameopts aq=7:cbr:br=96 "/home/keith/a directory with spaces/test.wmv"
    If I copy and paste the xvid.bat file to a terminal it runs fine.
  9. i use xterm to launch the encoding bat... could be this ?
    xterm -e "path to bat/xvid/bat"
    (any suggestion is appreciated!)
    i am too a command line guy but my knowledge of linux isn't to much (just installed 4 month ago)
    BHH
  10. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Buzz thanks for continuing to promote linux by porting more software over!
    Donadagohvi (Cherokee for "Until we meet again")
  11. thanks freebird73717!
    it's always a pleasure filling gap between windows and linux
    BHH
  12. update to 5.2 threads now work, added the possibility to specify threads
    http://www.64k.it/andres/data/automen/automen52
    next is to fix space issue
    BHH
  13. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    52 doesn't seem to work.
    bash-3.1$ chmod +x automen52
    bash-3.1$ ./automen52
    Segmentation fault
  14. here is ok... maybe a corrupted file
    try this http://www.64k.it/andres/data/automen/automen52.tar.gz
    thanks!
    BHH
  15. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    That was quick
    I can confirm that threads are working as expected for xvid, lavc-mpeg4, and x264. But not mpeg2.
    For wmv, threads are enabled, but, wmv encoding (and flv) only support a single thread.
  16. thanks for feedback disturbed1!
    update the link of first thread
    BHH
  17. update to 5.3
    now path with space and file name with space will work
    added queue
    BHH
  18. HDConvertToX, AutoMen, AutoMKV Developer
  19. update automen
    some fixing to queue
    added possibility to use ffmpeg for piping to x264
    BHH
  20. update
    added a better support for dvd input
    automatic crop on loading file
    more deeply autocrop
    added support for handbrakecli
    better support for crop for dvd input
    some gui layout change when users select handbrakecli
    BHH
  21. update linux build
    BHH
  22. Member
    Dec 2009
    Italy
    how can i import megui preset in automen (linux version)?
    Tnx
  23. update both 32 and 64 bit version
    changelog (trimmed windows only change)
    some cosmetic fixes
    added .mov as supported input file
    fixed detection of ffh264 codec
    update handbrake compatibility to 0.94
    update profile.txt
    better crop
    better decoding of mpeg2
    maybe better telecine
    now automen don't hang waiting mencoder to exit
    faster crop
    some layout changes
    better construction of batch
    automen will switch to handbrake when xvid+aac in mp4 is requested
    fixed framerate muxing when selectin deinterlace filter that decimate
    added more tips
    added recheck media with handbrake
    fixed computing of dvd lenght
    fixed dealing with xvid source
    whenever aac audio is selected is used handbrake
    added support for ffmpeg2theora
    BHH
  24. uploaded a new build of automen
    now only for 32bit
    i will upload a 64bit soon
    fixed CRF + 1 Pass not starting encoding
    fixed missing default encoder
    fixed detection of ffh264, lagarith, mjpeg, ffdivx,ffvc1 codec
    update applications
    fixed some layout compatibility with linux
    fixed size of embedded subtitle (when reencoding from mkv and using mencoder)
    added more tips
    fixed detection of audio when dealing with IFO/DVD input
    added detection of dvd subs
    added possibility to disable multithread
    fixed missing automatic output for theora output
    fixed 2 pass encoding with ffmpeg2theora (missing stats declaration)
    fixed use of lavf demuxer with interlaced source
    added support for ffmpeg.exe encoder
    added support for threads on ffmpeg
    better support for evo files
    added detection of OGV files
    better detection with handbrakecli analysis
    added tooltip
    BHH
  25. update automen
    fixed No Audio in 2 pass encoding
    BHH
