I have some WMV files I'm trying to turn in to a DVD using convertxtodvd
I've used the recommended settings of medium, etc and not really changed anything from the default. However the audio comes out on them pretty bad. There is a lot of garbage in the audio and its pretty terrible to listen to. Listening to the WMVs is perfectly fine. I've tried twice now and before I blow another DVD, I wonder if anyone else has run into this trouble or a setting I can try to change that might make the audio better.
Is your convertxtodvd version up to date?
You don't have to burn the dvd; check playing it on the PC before wasting a disc -
Have you tried these files in the newer DVD players like the Pioneer that will accept WMV files? Might be better in the long run than converting, especially if you start to acquire a lot of them....
No, I don't have any access to anything like this. This actually a DVD I'm putting together for someone, I have no idea what they have for a DVD player, so I'm just making a standard DVD.
actually on the last attempt I played it from the hard drive and it appears to be a problem with my dvd drive. It sounded fine on the hard drive. I've never had a problem with other DVDs sounding strange... I've burned it and given it to my friend I'll see if it sounds okay as I didn't have a DVD player to test it on.
Movie_LeftEye.wmv + Movie_RightEye.wmv + Polarized glasses = ?
By barelief in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Nov 2011, 16:45 -
combining WMV movie clips into one WMV clip
By blkwht240 in forum EditingReplies: 3Last Post: 5th Feb 2010, 01:41 -
1080p WMV to 720p WMV?
By TekMerc in forum Video ConversionReplies: 4Last Post: 7th Jan 2009, 15:41 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16 -
.flv to .wmv or wmv. to mpg
By LITEONDVD in forum Video ConversionReplies: 5Last Post: 29th Jul 2007, 19:02
