I am using iMovie to cut my movies. My clients want to watch them in the office on their office computer. They are not allowed to install any software such as VLC or plugins. They do have the Windows Media Player only.
So which format/codec/settings do you recommand for those machines?
I am currently exporting from iMovie and getting a .m4v file which I would like to convert via ffmpegX.
Thanks for your knowledge.
Results 1 to 18 of 18
I encode to iPod H264 (640x) and have had no problems playing such files on any PC at the two schools where I teach. (These files are ".mp4"). I use both ffmpegx -and- MPEG Streamclip.
Jagabo's answer is the best one offered so far. Without the installation of third-party software, MPEG1 or WMV are about the only reasonable-quality codecs guaranteed to be supported out of the box. If someone has been kind enough to install some other software, you may have more options, but without knowing what (if any) those are, you're pretty much limited to these two choices.
Yes, that is the way Microsoft wants it. As I noted, MPEG1 is also supported.Originally Posted by BMX2000
I don't deal much with WMV but WME is probably your best bet on a Windows system. Although you may have to convert to some intermediate format for WME to open your sources.Originally Posted by BMX2000
BMX2000, since I'm getting the feeling you aren't too crazy about .wmv, another option would be to package the video with media player classic. It will play a multitude of different file types and since it is a standalone player (a single executable file) it requires no install on the client machine. You could even make a .bat file that would launch the video (or a playlist of videos) with a single click (err..double-click).
I recently made a slideshow for a friends wedding that had a video intro that was a 720p (16:9 aspect ratio) WMV file and the slideshow itself was XGA (4:3 aspect ratio) MPEG2 file. Since I am showing it on an XGA projector I didn't want to lose resolution by putting it to DVD so I just made a playlist for both files and made a .bat file to open the playlist up and play the videos one right after the other in fullscreen mode. Noone will know that it's 2 different video files.
@greamalkin thanks for that other new idea. It is pretty clever!
I just started a testing with all the different options.
It seems to be so that on a Windows XP an .avi File with DivX 3 and MP3 in it runs as well without any plugins...
If this turns out true and reliable this option will be my 1st choice.
Do people a favor and use a newer version of Divx or Xvid. MPC will play those as well and they're more widely supported in case anyone wants to use the video elsewhere.Originally Posted by BMX2000
And if you are saying that a DIV3+MP3 AVI will play on a Windows system without MPC (or some other player with a built-in DIV3 decoder) that's not true. Divx 3 does not come with Windows and must be installed for WMP or any other player without a built-in DIV3 decoder. WMP's automatic codec download feature won't install it either.
any good "my movies" plugins for Windows media Center?
By craig198 in forum Media Center PC / MediaCentersReplies: 0Last Post: 26th Jan 2011, 14:47 -
windows media encoder plugins
By river3 in forum Video Streaming DownloadingReplies: 0Last Post: 4th Jun 2010, 03:15 -
Need a lossless codec that works in Windows 7/Vista
By LSchafroth in forum EditingReplies: 13Last Post: 25th Nov 2009, 11:12 -
Anyone know how Windows folder VIEWS works?
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 26th Oct 2009, 12:52 -
How Windows Media Encoder Works
By i-developer in forum Video Streaming DownloadingReplies: 1Last Post: 20th May 2009, 19:21
