i was told it works but this is the error message im getting:
warning File "C:\Users\***************\****tt.ts" ignored. Unknown file format.
warning Cannot get stream information. Maybe file format [dts] was misdetected due to incorrect file extension.
anyone know why???
				Results 1 to 13 of 13
	General
 Complete name : C:\Users\*******************\**tt.ts
 Format : MPEG-TS
 Format profile : No PAT/PMT
 File size : 2.02 GiB
 Duration : 2h 32mn
 Overall bit rate : 1 894 Kbps
 Video
 Format : MPEG Video
 Format version : Version 2
 Format profile : Main@Main
 Format settings, Matrix : Default
 Duration : 2h 32mn
 Bit rate mode : Constant
 Bit rate : 1 659 Kbps
 Nominal bit rate : 1 862 Kbps
 Width : 704 pixels
 Height : 480 pixels
 Display aspect ratio : 4/3
 Frame rate : 29.970 fps
 Colorimetry : 4:2:0
 Scan type : Progressive
 Bits/(Pixel*Frame) : 0.184
 Audio
 Format : MPEG Audio
 Format version : Version 1
 Format profile : Layer 2
 Bit rate : 160 Kbps
 Channel(s) : 2 channels
 Sampling rate : 48.0 KHz
 Resolution : 16 bits
 Video delay : -532ms
	Thus far, I've only done a few .TS conversions with ConvertX, but it seems to be one of the only tools that can do this (?). No problems with the ones I did. Keep in mind that ConvertX gets fairly regular updates, and some releases have fixed significant bugs. When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
	. . . Meaning that you compared the version # reported by ConvertX --> Help against the latest version listed in the Tools section here, or at the ConvertX site, and they were the same ?Originally Posted by jcurrieirocz
 I just hit a couple of unusual problems (not involving .TS files), noticed my installed version is two or three versions behind, so I'm about to update. Might help, might not, but I figure I should try it.
 One really good thing about the Tools section here is the direct "Mirror Download" links the VH admins try to include for most programs, wherever possible. In the case of something like ConvertX, this saves us from having to hunt around and drill down on the program's site. New releases there can be hard to find otherwise, or not distinctively named by version #. Sometimes a program has a nice built-in hook for retrieving its own updates, but you can't always count on that.When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
	Until you get it sorted, (and if you want to get it done now), you could run the *.ts file through HDTVtoMpeg2, then feed the MPEG to ConvertXtoDVD. If it doesn't accept the file either, you'd know the file's buggered. Its editing ability is minimal, but it has a commercial detector that works fairly well.
 Just a thought. Good luck. Pull! Bang! Darn! Pull! Bang! Darn!
	Did you try Soopa's suggestion? Often transport streams have errors and desynchronizations that can be fixed (if they are tiny) when you "remux" it back into the same container
 Another possibility is that it is truncated and the first few frames are damaged. You could try cutting the 1st few frames off with TsMuxer, or even avidemux.
 Another option: since it's a MPEG2 transport stream, projectx and pvastrumento are good choices for "fixing" streams.
 Once you "fix" it, try plugging it back into convertxtodvd
	ok i understand the first few frames bit but when i load the file into the program and i click on it before i hit the convert button it shows in "audio stream" a zero,, i assume that means my whole file will be converted with no audio at all, not just the 1st couple frames.
	Which program are you referring to when you say "the program"? Have you tried any of the suggestions so far?Originally Posted by jcurrieirocz
 Most programs will read the inital bit and/or header to parse the stream. If it is damaged it can report the audio as "0", that is why you should either fix it first, or cut the bad frames.
	i meant convertxtodvd when i said program. No i didnt try any other programs yet. once i get my other conversion in my other post figured out ill try some of the other programs here on this issue.....too many programs for two conversions ill get mixed up. Thanks for all your guys help!!
	ive been thinking if this conversion was a one shot deal id go to all the trouble to fix it but sence i want to later do alot of these ts to dvd conversions ill wait till i can find a one program fix for it,,,,untill then ill just use the dvd recorder to get around it.
  Can I batch convert with convertXtoDVD?By coopgang in forum Video ConversionReplies: 10Last Post: 23rd Jun 2010, 07:15
  New MKV File-convertxtodvd won't convert it.By jbitakis in forum Video ConversionReplies: 17Last Post: 4th Feb 2009, 15:51
  Can ConvertXToDVD convert from and too all of these?By wetcamelfood in forum Video ConversionReplies: 2Last Post: 5th Jan 2009, 02:10
  Convertxtodvd wont convert audio in .avi to dvd....................By jcurrieirocz in forum Video ConversionReplies: 14Last Post: 5th Nov 2008, 18:15
  ConvertXtoDVD doesnt convert entire fileBy rperson989 in forum Authoring (DVD)Replies: 3Last Post: 21st Oct 2007, 06:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
