I have a Sapphire X1600PRO HDMI graphic card with HDMI dedicated output interface on card. I have had it for about 1.5 yrs and i am ready for a upgrade.
Which do you suggest is better?
GeForce™ 9600GT Sonic
http://www.palit.biz/main/vgapro.php?id=629
or the
9600GSO-384X
http://www.albatron.com.tw/English/product/vga/pro_detail.asp?rlink=Specification&no=246
It's the same chipset, you aren't likely to notice much difference between the two. Typically, you'd watch clock speed and memory size. Of those two, I'd get the 9600GT. You can see some comparisons here: http://www.tomshardware.com/charts/gaming-graphics-charts-q3-2008/3DMark06-v1-1-0-3DMa...Score,794.html
Google is your Friend -
I recently got a ATI HD 3870 video card for use with Blu-ray>HDMI and it works very well. Gave my Vista computer a 5.9 in both graphics ratings and still at a reasonable cost. (~$130US)
http://www.overclockersclub.com/reviews/sapphire_hd_3870/15.htm
Does Graphic Card Makes any Difference in Video Conversion?
By farzad in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 18:20 -
How To Install A Graphic Card Correctly?
By themaster1 in forum ComputerReplies: 16Last Post: 21st Jan 2010, 23:22 -
best silent graphic cards with hdmi+dvi out and hdcp support
By deejay.2001 in forum ComputerReplies: 5Last Post: 13th Jan 2009, 14:01 -
Graphic card ?
By Dash1 in forum ComputerReplies: 7Last Post: 3rd Dec 2007, 12:53 -
CPU and Graphic card
By hanugro in forum ComputerReplies: 8Last Post: 5th Jun 2007, 21:05
