Must be something I mis-set. It used to work fine. Have downloaded IMGBurn. Would very much appreciate help in the most basic of terms - I am not well informed as far as computer language and acronyms go. Many thanks in advance.
-GeneHal
Results 1 to 10 of 10
Sorry, Budz. If I put any DVD into the DVD drawer of my desktop computer and open and try to run DVDFab Platinum (DVD to DVD Full Disc), I see the message in the Source box "Please insert DVD disc or choose DVD folder/image file". In other words it is not picking up on the fact that there IS a dvd in the dvd drawer. Hope that is a bit clearer and
appreciate your tolerance and help. -
Does it happen with one particular dvd disc or with any dvd disc?
Budz,
It just made a liar out of me. Hold on please. It did recognize presence of a different DVD I put in. Yikes! -
Real puzzlement. It's now recognizing the discs it did not recognize before. Have no idea what is going on.
Budz,
Problem 2: when it comes time to write to the new DVD it refuses to recognize Memorex brand discs. I have some Verbatim discs coming from Amazon. Hopefully it will recognize them. Again, thanks for your fast, helpful replies. -
Your welx!
MEMOREX is the problem cause they are considered crappy media. Use VERBATIM or order some TAIYO YUDEN from www.rima.com. -
You're a real mensch, Budz. And if there is anyone around ancient enough to remember Edgar Bergen, I'm like his "pal". (smile).
Cherrz!
DVD inserted/ejected not recognized in DVDFab DVD Copy
By WebMaximus in forum DVD RippingReplies: 11Last Post: 1st Jan 2012, 07:22 -
DVD to iPoD/PSP/Cell phone/PCP including subtitles using DVDFab Platinum
By Baldrick in forum User guidesReplies: 6Last Post: 14th Nov 2009, 15:09 -
dvdfab platinum and dvd hd decrypter
By marioval in forum DVD RippingReplies: 4Last Post: 8th Jan 2008, 15:40 -
XBOX 360 converting (dvd to xvid) with dvdFAB Platinum
By devGOD in forum DVD RippingReplies: 6Last Post: 12th Dec 2007, 17:49 -
dvdfab platinum dvd to ipod audio low!!!
By Jorge in forum DVD RippingReplies: 7Last Post: 6th Sep 2007, 10:59
