I have MPC (latest version) set as my default player for .avi, and it works fine for every kind of .avi movie (from my camera, internet downloads, etc.) EXCEPT the screen capture movies I make with CamStudio (2.0).
When I try to watch one, the MPC video window "compresses" vertically and the sound slider moves along, but I can't see the picture.
I can watch them just fine with the CamStudio player and Camtasia Studio (v 3.1.2) Player, but not with Media Player Classic.
I have the latest version of ffdshow*, and GSpot shows I already have the right codec installed on my machine.
Something, is obviously configured wrong, but I can't for the life of me figure out what it is.
I'll sincerely appreciate any help you might have to offer.
Thanks in advance.
* It's interesting: When I watch some .avi movies, the ffdshow icon opens on my task bar, but not others. I have no idea what the difference is among the various (at least 3 types) of .avi files I apparently have here and there on my machine.![]()
Lenovo ThinkStation P520, Xeon W2135; Win10Pro x64, 64Gb RAM; RadeonPro WX7100W; NEC PA301W, NEC PA272W, and Eizo MX270W.
Do you have the CamStudio capture codec installed? Just curious.
Go to your Start menu folder for ffdshow, and run:
VFW configuration > Codecs
Video decoder configuration > Codecs
(...but not necessarily both at the same time.
In both, there should be an entry for "CamStudio." Make sure both are set to "libavcodec" and not "disabled," then use the OK button to close the windows. Then, try playing the video(s) in MPC again.If cameras add ten pounds, why would people want to eat them? -
Thanks very much for your reply.
Everything is set the way you suggested, and, yes, I have the CamStudio codec v. 1.4 (I've also just tried it with v. 1.0).
It still doesn't work.
Are there any special settings needed in MPC?
By the way, it worked once upon a time, and if I remember right, the problem started after an update of ffdshow.
I have a sickness that makes me update ffdshow every time I see a new version.
As I've said, I can watch the movies both in the CamStudio and the Camtasia Studio players - which, I guess, are pretty much the same thing.
I'll appreciate any other ideas.
Thanks in advance.Lenovo ThinkStation P520, Xeon W2135; Win10Pro x64, 64Gb RAM; RadeonPro WX7100W; NEC PA301W, NEC PA272W, and Eizo MX270W. -
I'm not sure I had a problem playing videos encoded with the CamStudio codec in MPC... after headaches trying to get the video converted to a different codec afterward, I tended to avoid using it.
Do the videos play in Windows Media Player?
Not sure if VLC or mplayer support the codec; I doubt it, though. Just to be on the safe side, you might also run one of the videos through GSpot or MediaInfo and post the information here (blank out file and path/system information if you prefer). It might show if there's something else that's preventing it from playing.If cameras add ten pounds, why would people want to eat them? -
Hi and thanks for your reply. No, they don't play in Windows Media Player either. I've run the file through GSpot. It says the codec I need to play the film is installed.
By the way, as I said, it used to work, but somewhere along the line - after I updated something or other - it stopped.
Since the films do play in both the CamStudio and (related) Camtasia Studio players, I really think it's something with MPC.
If it's of any interest, the films I make with Camtasia Studio work just fine.
Anyway, thanks.Lenovo ThinkStation P520, Xeon W2135; Win10Pro x64, 64Gb RAM; RadeonPro WX7100W; NEC PA301W, NEC PA272W, and Eizo MX270W. -
No, I meant post a GSpot screenshot (or copy and paste the MediaInfo information here); someone might see something in the information that could cause a problem. GSpot also has a rendering path test (lower left corner) that you can use to see what steps the system will take to play the video, and if there are any problems. (And, if GSpot's able to play the video correctly, too.)
That MPC and WMP are both unable to play the video implies it's a codec/DirectShow problem, not with MPC. Though, I'm certainly not ruling anything out, yet.If cameras add ten pounds, why would people want to eat them?
By Soixante in forum Software PlayingReplies: 4Last Post: 16th Sep 2010, 18:11 -
Problem using Media Player Classic home cinema player
By True Colors in forum Newbie / General discussionsReplies: 7Last Post: 18th Apr 2010, 08:30 -
Streaming FLV in WM Player or Media Player Classic
By jlz901 in forum Video Streaming DownloadingReplies: 0Last Post: 21st Mar 2010, 12:09 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
Media Player Classic and Windows Media Player 9.0
By siluet in forum Software PlayingReplies: 0Last Post: 26th Dec 2007, 11:01
