I hope this is the correct section for my problem.
I am trying to make a game video from COD4, using x264 as encoder.
I am taking the following steps:
1.) extract the ingame content to an image sequence, in this case TGA @ 1280x720 @ 300 fps.
taking 20 seconds with each picture consuming about 2,7MB, i will end up with about 15GB worth in TGA files :S
2.) store them TGA files in a lossless video file to save on diskspace.
i use this:
x264 --qp 0 -o output.264 input.avs
input.avs:
Code:ImageSource("shot%04d.tga", 0, 6000, 150) AssumeFPS(300) ConvertToYV12() SelectEvery(2, 1)
the output file will have 1,4GB.
but when i play it, it will look much like this:
i tried with vlc and mplayer.
if i use
instead, the output file looks proper - so apparently i have a problem with encoding lossless h.264 files...x264 --qp 1 -o output.264 input.avs
any suggestions :S
I think only CoreAVC can decode the new lossless x264 (High 4:4:4 Predictive), libavcodec, ffmpeg cannot - therefore VLC, Mplayer won't be able to play it.
You would save more space if you didn't use lossless x264; I bet if you used CRF16, it would be near lossless (virtually indistinguishable) and 3-5x smaller filesize - do some short tests
This might be unrelated, but there have been a few bug reports of distortion with x264 r994-r999, and it's being worked on - check Doom9 forums for details. Use an earlier x264 version if you want to be sure -
hi, thanks for the quick reply.
a friend sent me a lossless x264 file to test, and that one played well, i guess it was produced with an older version then?
edit: scrap that lol, i am tired -.-
i don't want to use commercial stuff, so i will go for another solution then. CRF16 sounds nice, i will try that.
i also read about this MSU codec, is it any good? will i have to use Vdub to encode with it, or is there a standalone encoder like x264? -
CRF16 is just a constant quality level, not lossless mode.
http://mewiki.project357.com/wiki/X264_Settings#crf
Lower is "better" quality, so CRF14 would be even better statistically with a larger filesize. Visually I doubt you could tell the difference frame-by-frame between CRF14 and 16. But depending on what your source format is, the color maybe better with true lossless mode. Again, just do some short sample tests and make sure you use proper decoder & renderer settings when playing (e.g. overlay mixer will display better color saturation vs. VMR9renderless on the same file)
I would use an older version of x264 for now, you can check which version was used in your friend's file with mediainfo (view=>text)
I'm not familiar with MSU codec, perhaps someone else can answer... -
i just tried with crf16, and its awesome
instead of almost 300MB, i now have a bit more then 30MB now, thats insane
the output is slightly darker then the original, but thats actually not that bad.
thanks alot! awesomeness!
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 18:29 -
Lossless AAC file editor?
By sldvd in forum AudioReplies: 1Last Post: 26th Oct 2010, 18:28 -
Lagarith or x264 lossless?
By sphinx99 in forum Capturing and VCRReplies: 42Last Post: 7th Jun 2010, 08:13 -
Color problem with x264 output + other x264 questions
By serexl in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 18:31 -
Single huge lossless AVI file index problem
By Gargalash in forum Newbie / General discussionsReplies: 12Last Post: 20th Nov 2009, 18:37
