Have weird problem with Sony Vegas pro 8.0
The problem is for example when you have split a clip, take out the unwanted bit, then try to join the clips you want together, by moving them in the timeline, they just will not move!
Every time I try to put two segments together, they jump back to the original places where they were before.
Most of the advice I had was to switch off auto ripple, which I did and also tried virtually every possible option and setting, but it made no difference whatsoever, problem still persists!!
Also noticed on the actual program display when trying to adjust the timeline window and the left window with track details, this also does the same and windows just jump back to previous state, although adjusting the windows horizontally between time line and above Tabs/Icons part then it works.
Anyone come across this before?
Results 1 to 1 of 1
Sony Vegas 8 Pro rendering problem
By windyangel in forum EditingReplies: 1Last Post: 16th Jul 2009, 02:00 -
Sony Vegas Pro 8 problem
By Huynhjoh in forum EditingReplies: 1Last Post: 27th May 2009, 09:10 -
By Huynhjoh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 27th May 2009, 09:06 -
Problem with capturing video from webcam from Sony Vegas 8 Pro.
By videodirector in forum Newbie / General discussionsReplies: 0Last Post: 7th Mar 2009, 03:51 -
Problem with swirl video fx on sony vegas pro 8
By stealers in forum EditingReplies: 1Last Post: 30th Dec 2008, 20:27
