There's something funky going on with my Vegas timeline. I wanted to insert something on the timeline at 2:00 minutes exactly, and I zoomed and zoomed and find there is no 2:00! What happened here? See Screenshot
Turn off drop frame. It's all about matching 59.94 fields per sec. to real time duration.
I don't have Vegas on this laptop so consult Vegas help for "drop frame" setting.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
It's always been set on SMPTE Drop, and it is now.. this is with the semi-colon preceding the frame numbers in the timecode..
I was suggesting you try turning drop frame off (no semicolon).Originally Posted by sdsumike619Recommends: Kiva.org - Loans that change lives.
Drop frame is the default for broadcast TV where they need to match a realtime clock to hundredths of a second. If you turn drop frame off, there will be a small error in timecode reported program length due to 59.94 video fields per second instead of 60.
http://en.wikipedia.org/wiki/SMPTE_time_codeRecommends: Kiva.org - Loans that change lives.
This is not for broadcast, just standard NTSC DVD.. I use Adobe Encore DVD for my authoring, and I think it uses Drop Frame, so I really would like to get this fixed otherwise I think the time will be off for setting my chapter markers when I go to do the authoring..
Sony Vegas Red JPGs on Timeline ?
By blewyn in forum EditingReplies: 4Last Post: 5th Feb 2012, 20:23 -
Vegas: Timeline pictures?
By duderdude2 in forum EditingReplies: 4Last Post: 18th Feb 2010, 20:22 -
Sony Vegas: Timeline Cropping
By mltwitz in forum EditingReplies: 9Last Post: 29th Aug 2009, 05:16 -
Timeline in Vegas 8?
By guzzi in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2008, 19:48 -
Searching specific frames in VEGAS timeline
By schematic2 in forum EditingReplies: 5Last Post: 21st Apr 2008, 07:52
