i was capturing old movies from my vhs collection when this message appeared. perhaps this maybe the reason why my finished captured file has a swirly looking line at the bottom of the viewing screen. if anyone know answers to these questions, please answer them for me. thanx everyone for helping me out
1% frame dropped is nothing it should'nt affect in anyway visible it only means you've lost 1 frame per hundred... 1 frame per 4 secs... as for the line i don't know if i see something. i'll get it to you aas soon as possible
That line is a typical VHS artifact. You don't see it on TV because of overscan, but it is allways there. Just crop it out. 1% frame loss is also nothing to worry about (if you didn't lose all frame at once)
First, What are you capturing with??
Second, I assume that your capture was terminated when when this meesage came up.
If you are using Virtual dub, then it probably means that you have a condition set in the 'stop conditions' settings. It allows you to set a stop condition based on the number of frames dropped. You may have it selected and set to 1%. (If my assumptions are wrong...hope you get some help elsewhere)
Regarding the dropped frame rate.....1% probably won't be all that noticable but you should be able to do at least 10 times better than that....so keep trying! -
To me, it is better if you loose less frames, so, I'm saying you should be able to get below 0.1% loss of frames (ie less then 1 in 1000...I average about 1 loss in 5000 at the moment)
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
dropped frames capturing 1080i w/ Intensity Pro
By dvanoltri in forum Capturing and VCRReplies: 1Last Post: 21st May 2010, 16:10 -
Capturing nightmare. It's driving me insane. Dropped Frames only problem.
By Legit Nukes in forum Capturing and VCRReplies: 8Last Post: 27th Mar 2010, 01:34 -
Getting artifacts and dropped frames capturing DV
By CleanRich in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 1st Nov 2007, 19:54 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
