Hello all,
I have VideoRedo Suite the latest version and when I go to cut up a 30 mins show it says the output file will be 22 min however its only 12 mins. Any suggestions? This happens on all my files and this is a purchased version too. If I do an hour program it will show the output at around 42 mins but then only output 20 or so.
Chad
Try a Quickfix on the video file first, then cut the fixed video file and see if you have the same problem.
Jerry
Intensity Pro Output 60FPS issue
By Zarukei in forum Newbie / General discussionsReplies: 2Last Post: 31st Jan 2012, 20:19 -
File output issue from TMPEnc Author Works, VOBs -> single MPEG2
By aln688 in forum Video ConversionReplies: 4Last Post: 10th Apr 2010, 20:17 -
VideoReDo doesn't Save/Output entire file after editting out commericals
By peter11815 in forum EditingReplies: 1Last Post: 19th Sep 2009, 14:41 -
VideoRedo->DVRMS Issue, VideoRedo->MPEG2 Fine, Please Help
By tbrnet in forum Video ConversionReplies: 0Last Post: 10th Jan 2008, 16:43 -
Trying to trim video with VideoRedo but output file is a fraction
By geek2330 in forum Newbie / General discussionsReplies: 6Last Post: 21st Nov 2007, 19:45
