My car radio sometimes just outputs the right channel. But if I turn the volume up, it switches back to stero.
This is the second audio unit in the same vehicle so I know it isn't the radio.
What should I be checking?
Sounds to me like a poor connection offering high resistance. Check and reseat your speaker wiring connections. If they're alright and reseating doesn't fix the problem, then it's probably a pinched/worn spot someplace in the wiring harness, most likely where the wire passes through any structural steel or maybe pinched behind any decorative molding.
Buy My Books -
Is the slot you have your stereo mounted in deep enough to hold it?
It could be pushed to close to the firewall or something inside the dash and smashing the connections and wires on the back."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!"
Question about good mp3 player to car radio transmitter
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 4th Oct 2010, 19:47 -
Rear projection HD tv picture fault
By Stedalton in forum DVB / IPTVReplies: 0Last Post: 22nd Jun 2010, 13:16 -
ipod 160gig screen fault?
By angryassdrummer in forum Portable VideoReplies: 0Last Post: 7th Jul 2009, 00:45 -
Segmentation fault while executing dvdauthor
By mmasroorali in forum Authoring (DVD)Replies: 3Last Post: 17th Oct 2008, 19:33 -
fault on toshiba rd-xs24
By superray in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Dec 2007, 07:31
