Error Signature
AppName: Virtualdubmod.exe
AppVer 1.5.10.0
ModName: Kernel32.dll
ModVer: 5.1.2600.5512
Offset: 00012aeb
Results 1 to 11 of 11
Remove everything from the plugins folder. Does it still crash?
It could also be a bad VFW codec. -
There is a VirtualdubMod 1.5.10.3 here if you're interested. He also has the latest Virtualdub and filters.
http://www.virtualdub-fr.org/telechargement
Another VirtualdubMod build here, VirtualDubMod Surround 1.6.0.0
http://www.aud-x.com/index.php?option=com_content&task=view&id=12&Itemid=26 -
Are you installing the entire VDubMod package, or downloading the update? (I know at one point they had an 'update' that only included the main .EXE and one or two other files.) Also, are you extracting everything from the .zip archives with the subdirectories intact? VirtualDubMod is a bit more critical about all of its files being in the proper place than VirtualDub.
...and speaking of VirtualDub, do you have any problems running that?If cameras add ten pounds, why would people want to eat them? -
i figured it out. so i was using gordian knot and i also installed avi synth 2.5 and it ended up that avi synth was making it crash. once i uninstalled the avi synth it opened up perfectly
Just letting you guys know that I too had encountered this problem tonight. I had built a new pc and this was my first time running vmod on it with the same crash upon the double click to start the programOriginally Posted by DarrellS
my old pc where it worked fine was a win xp 32 bit home,
this new pc is a win xp 32bit pro
I do not use avisynth, however dvdrebuilder requires it and installs ver 2.5 on your pc. Dvdrebuilder works fine on my new pc as well (though I did update avisynth after reading this post).
reading the posts, I downloaded a the slightly newer build from http://www.virtualdub-fr.org/telechargement which was listed above. In addition to this you should download the plugin package made to go with it (even though the instructions say to put them in a plugin32 folder, copy them to the regular plugin folder instead).
This version works and can now even input more than my previous Vdubmod could. No idea what was truly causing the error but at least with this build I no longer have to worry about it
Help please:Virtual VCR crashes on startup
By cgarai in forum Capturing and VCRReplies: 10Last Post: 11th Apr 2012, 14:53 -
Virtualdub kernel32 error, TMPGEnc cutting video
By koberulz in forum Newbie / General discussionsReplies: 5Last Post: 11th Apr 2012, 11:36 -
CloneDVD 2 crashes at startup
By pacopaco in forum DVD RippingReplies: 3Last Post: 24th Jan 2008, 14:28 -
vob2mpg crashes during startup
By ragu6307 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 31st Dec 2007, 17:29 -
Error on startup
By bush in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 22nd May 2007, 18:30
