I am a newbie when it comes to video editing, so I'm not sure where to start on this.
I'll start by giving you the details:
I recently created a VIDEO_TS DVD structure using QDVDAUTHOR in Ubuntu Linux. It is a DVD with 2 video files and a single menu with background audio. I have not burned the DVD yet, it is still only on my hard drive. When playing the DVD folder with VLC Media Player, everything works perfectly as expected except the pitch of the Audio in both Videos is too high. All the voices sound almost "Alvin & The Chipmunks" like. My question is, is there a way I can fix this without doing any major re-encoding or transcoding?? Can I just somehow strip the audio track off of the VOB files, edit it, then remux it back in? I have no idea where to start on this, so I thought I would ask here.
I think maybe editing some of the encoding commands in QDVDAUTHOR might let me just re-author the DVD with the correct pitch, but I would have no idea which commands to edit or what I should change them to?
Now, I will give you the technical details of the situation:
I started out with 2 .avi files encoded with XViD:
Video File 1 Details:
Video File 2 Details:Code:Format : AVI Format/Info : Audio Video Interleave File size : 697 MiB Duration : 1h 28mn Overall bit rate : 1 105 Kbps Writing application : VirtualDubMod 1.5.4.1 (build 2178/release) Writing library : VirtualDub build 30009/release Video Format : MPEG-4 Visual Format profile : Streaming Video@L1 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Custom Codec ID : XVID Codec ID/Hint : XviD Duration : 1h 28mn Bit rate : 968 Kbps Width : 640 pixels Height : 352 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.179 Stream size : 610 MiB (88%) Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01) Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 1h 28mn Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 80.7 MiB (12%) Alignment : Split accross interleaves Interleave, duration : 42 ms (1.00 video frame) Interleave, preload duration : 500 ms
Code:Format : AVI Format/Info : Audio Video Interleave File size : 680 MiB Duration : 1h 27mn Overall bit rate : 1 086 Kbps Writing application : AVI-Mux GUI 1.17.7, Aug 8 2006 20:59:17 Writing library : VirtualDub build 30009/release Video Format : MPEG-4 Visual Format profile : Streaming Video@L1 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Custom Codec ID : XVID Codec ID/Hint : XviD Duration : 1h 27mn Bit rate : 948 Kbps Width : 720 pixels Height : 416 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.132 Stream size : 594 MiB (87%) Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01) Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 1h 27mn Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 80.1 MiB (12%) Alignment : Split accross interleaves Interleave, duration : 42 ms (1.00 video frame) Interleave, preload duration : 500 ms
Here are the commands that QDVDAUTHOR used when authoring the DVD:
Code:cmd> if [ ! -e "/tmp/Movie/qdvd.fifo" ]; then mkfifo -m 777 "/tmp/Movie/qdvd.fifo"; fi; cat "/tmp/Movie/qdvd.fifo" | mp2enc -b 192 -r 48000 -o "/tmp/Movie/menu.mp2" & mplayer "/media/DATA/DVD Backgrounds/menu.mp2" -vo null -ao pcm:file="/tmp/Movie/qdvd.fifo" cmd> #=- VideoTrans -=# /media/DATA/TEMP/video1.avi cmd> movie-to-dvd -M -c mp2 -a 16:9 -f audio -m ntsc -o "/tmp/Movie/Video1/" "/media/DATA/TEMP/Video1.avi" && mv "/tmp/Movie/Video1/Video1.vob" "/tmp/Movie/Video1/Video1.mpeg2" cmd> #=- VideoTrans -=# /media/DATA/TEMP/Video2.avi cmd> movie-to-dvd -M -c mp2 -a 16:9 -f audio -m ntsc -o "/tmp/Movie/Video2/" "/media/DATA/TEMP/Video2.avi" && mv "/tmp/Movie/Video2/Video2.vob" "/tmp/Movie/Video2/Video2.mpeg2" cmd> jpeg2yuv -n 5124 -I p -f 29.97 -j "/tmp/Movie/Main Menu VMGM/background.jpg" | mpeg2enc -n n -f 8 -a 2 -o "/tmp/Movie/Main Menu VMGM/menu.m2v" cmd> mplex -f 8 -S 0 -M -o "/tmp/Movie/Main Menu VMGM/menu.mpg" "/tmp/Movie/Main Menu VMGM/menu.m2v" "/tmp/Movie/menu.mp2" cmd> spumux -m dvd "/tmp/Movie/Main Menu VMGM/menu.xml" < "/tmp/Movie/Main Menu VMGM/menu.mpg" > "/tmp/Movie/Main Menu VMGM_menu.mpg" cmd> dvdauthor -x "/tmp/Movie/dvdauthor.xml"
The part that really interested me however, was this statement at the beginning of processing each video in the QDVDAUTHOR output:
And the same for Video 2:Code:Finding properties for </media/DATA/TEMP/Video1.avi> --> Source video is 23.976 fps, destination is 29.970 fps. The audio will be played at 124.900% to avoid frame duplication or removal. --> Source has 48000Hz mad audio with 2 channels. Converting it to a 38400Hz WAV with 2 channels using mplayer because the pitch of the audio needs to be adjusted. Changing the pitch of the audio to 48000Hz using movie-fakewavspeed. Converting the audio from WAV to MP2 using mp2enc.
It clearly says it needs to adjust the Pitch of the audio. Is this my problem?Code:Finding properties for </media/DATA/TEMP/Video2.avi> --> Source video is 23.976 fps, destination is 29.970 fps. The audio will be played at 124.900% to avoid frame duplication or removal. --> Source has 48000Hz mad audio with 2 channels. Converting it to a 38400Hz WAV with 2 channels using mplayer because the pitch of the audio needs to be adjusted. Changing the pitch of the audio to 48000Hz using movie-fakewavspeed. Converting the audio from WAV to MP2 using mp2enc.
And, just in case you need it, here is the technical information for one of the VOB files that was created:
Code:Complete name : M:\Movies\VIDEO_TS\VTS_01_1.VOB Format : MPEG-PS File size : 1 024 MiB Duration : 54mn 13s Overall bit rate : 2 640 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, Matrix : Default Duration : 54mn 13s Bit rate mode : Constant Bit rate : 2 233 Kbps Nominal bit rate : 6 000 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 16/9 Frame rate : 29.970 fps Standard : NTSC Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.579 Audio ID : 192 (0xC0) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Duration : 54mn 13s Bit rate mode : Constant Bit rate : 224 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Resolution : 16 bits Menu Format : DVD-Video
Please let me know if I can just edit my VOB files or can I fix the problem by re-authoring with different settings.
When I make the same DVD with DVDStyler, it works fine, no pitch problems. However, DVDStyler doesn't let you add background audio to your menus, and I really wanted a background song for my menu, so that is why I am trying to get it to work with QDVDAUTHOR.
Any insight would be appreciated.
Thanks.
Yes, that's your problem. For some reason it decided to speed up both the audio and the video to 29.97fps, rather than applying 3:2 pulldown to the video and leaving the audio length untouched. I know nothing about Linux, but would suggest you never use that program again, and then do it right using a decent encoding and authoring app.It clearly says it needs to adjust the Pitch of the audio. Is this my problem?
Maybe you can apply 3:2 pulldown yourself using DGPulldown or Pulldown.exe which will have it output 29.97fps, but without speeding up the video. Also convert the MP3 audio to AC3 yourself. Any decent authoring program will then take the 2 and author them properly. But like I said, I know nothing about Linux or the programs available to you. If it was a Windows PC you could use FAVC or any one of a number of other programs to create the DVD. -
The machine also has Windows XP, so any Windows advice you can give me will be greatly appreciated also. I only used Linux because QDVDAUTHOR only runs on Linux and it is the only (FREE) program that I found that lets you create menus and add background audio to those menus. If you know of another FREE program that does this, please let me know. Does FAVC allow the creation of menus?
Thanks. -
Not really; it makes really basic ones over which you don't have much input, although if you know what you're doing you could edit them afterwards.Does FAVC allow the creation of menus?
If you're really particular about having your own designed menus, then your best bet is to split this project into 2 parts. The first would be the encoding of the video to a DVD compliant M2V (or just run the current M2V through pulldown) and reencoding the MP3 audio to AC3. The second would be the authoring stage using an authoring program with which you can design menus as simple or as elaborate as you wish, along with adding in audio. Two such free authoring programs are GUI4DVDAuthor and DVDAuthorGUI.
You may be able to use FAVC for at least part of this by having it save the elementary streams (the audio and video) rather than having them deleted after it makes the DVD. Then use the M2V and AC3 it creates for your own authoring. Or maybe you'll be satisfied with the simple menus it makes for you. -
You can do this easily. On the front Tab of FAVC there is a box marked Working Files, with a Keep and Delete option. Select Keep. The streams will be kept in the Temporary Files Folder selected on the same tab. If I need to very quickly encode a file and create a menu I will encode with FAVC and use the working files in DLP to finish off the disc.Originally Posted by manonoRead my blog here.
Thank you for all of the replies, but I have figured it out. I will post the answer here in case anyone in the future comes across this.
What I did was do some digging on the "movie-to-dvd" tool that QDVDAuthor uses to encode the VOB files and found that the settings just needed adjusted from the software author's peculiar default settings.
What needed to be done was change this:
To This:Code:movie-to-dvd -M -c mp2 -a 16:9 -f audio -m ntsc -o
According to the movie-to-dvd website, the -c switch controls the audio codec used, which was set to MP2 by default which only works for PAL according to the site. So, I changed that to ac3 to make it compatible. But the real change that helped my problem was changing the -f switch from "audio" to "video" which changes the way the application converts the frame rate.Code:movie-to-dvd -M -c ac3 -a 16:9 -f video -m ntsc -o
Here's an excerpt from the site:
-f method
Specify how to change the movie to adjust its framerate if necessary. You may specify either auto, video, audio.
video will duplicate or drop frames to adjust the framerate (which will make the movie jerky in some situations), and will keep the audio as it is.
audio will adjust the pitch of the audio track so that it runs synchronized with the movie if the movie would be played slightly faster or slower than normal because it’s new framerate is different from the original.
auto will make the choice for you. The choice that is made depends on the source video and the destination parameters that you are encoding to.
Problems editing .VOB files
By Jose_A_Duran in forum Newbie / General discussionsReplies: 7Last Post: 14th Feb 2011, 16:44 -
Editing one of the .VOB files
By Yaro in forum EditingReplies: 94Last Post: 4th Sep 2009, 16:52 -
Editing VOB files
By lika in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 14:51 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 08:31 -
editing vob files
By newtie in forum Authoring (DVD)Replies: 7Last Post: 5th May 2007, 10:19
