  1. Member nick101181's Avatar
    Sep 2000
    Toronto, Canuck Country
    Hello,
    I recently upgraded to an asus m3a78-em mobo and a amd 9950 125w quad core processor with 4gb of ddr2 pc 1066 ram. I had a divx file that wasn't compatible for my ps3, so I tried using ps3 video 9 and it said to encode to avc 480p it would take more than 2 hours for an hour and 20 min movie. Does this seem right? That encode time sounds close to my older computer which was an amd 64 3000+ with 1.5 gb of pc333 ram. I've never owned a dual core processor, so since I have a quad core, is there a way to tell the computer to use more than one core for encoding? I was thinking with such a huge leap in an upgrade, I would see phenomal encoding times, but maybe I'm doing something wrong. Any ideas?
    It's the application that needs to be multiprocessor-aware. As an example: On my Core2Duo Mac, XLD can handle two FLAC>ALE transcodings at about the same speed as it can handle one if you tell the app to look for a second core (or processor).
    Where you -should- see better performance (with your quad) is in running multiple applications; I'm assuming that XP Pro (what your profile says you're using) can handle multiple processors in that manner. Others will have to confirm this as, frankly, I run XP as little as possible.
    Good luck.
  3. PS3 Video 9 appears to support multithreading:
    http://www.redkawa.com/forums/showthread.php?s=9ca4d12563b0fee3fbbcf76192524b75&t=2138
    See the section entitled "Speeding up conversions for those with multi-core systems."
    Redding, California
    Using the Divx v6.8 codec (very PS3 friendly and uses all cores) and VirtualDubMod with Fast recompress should take about 15-20 minutes for your 1hr 20min movie.
    With the Q6600 quad core I get 160fps encoding speed and a P4 2.6gig cpu I get 30fps.
  5. Member nick101181's Avatar
    Sep 2000
    I'm currently using vista 64
  6. Member nick101181's Avatar
    Sep 2000
    thanks for the tip about divx and virtualdubmod, I'm averaging around 175 -240 fps and around 10 -15 mins for the fast compression
