hey everyone.... ive been reading a lot of posts and trying a lot of the things people recommended however i have been unsuccessful in taking a FLV video (whatever video it may be) lol and converting it and burning it to a dvd. i think the closest ive been to doing something right is i got it to an iso file blah not helping, can someone please post for me a step by step guide for converting a FLv video to whatever format it need to be avi or whatever and then burning it onto a dvd please post programs needed. thanks yall![]()
Results 1 to 9 of 9
convertxtodvd.
Or if you got an iso then just burn it using imgburn. -
I've always used DVD Flick to convert a bunch of FLV's to a DVD. Just open it, add the files to the list, set the options for NTSC or PAL and let it do it's thing. It will even give a simple menu, if you're using one of the newer versions. It burns your files to a dvd with ImgBurn. Oh, yeah, it's free.
thanks guys i havnt had a chance to do anything yet but im working on it now
props to balrick that program was exactly what i needed 2 clicks and its done thank to everyone
here i am still trying to figure this out...trying to gather enough knowledge to be able to know what question to ask and how to ask it. i have flv files from youtube-52 episodes in a serial, totalling 1GB in size as flv.
should i be using mpgI or mpgII? how do i get a log from anyconverter? would mpgI and mpgII be way different in size after conversion? i converted to mpg using AnyConverter and the file more than doubles.
using dvdflick i get a single file that was under 20MB expanded to 570MB. is that what is supposed to happen? even though that is too big for my project (i want to make a dvd-or even two discs would be ok) to play on a standalone dvd player using pal.
i understand bitrate can be adjusted but i dont know if i can change the video without touching the audio bitrate. i am already 62 years old, i may die of old age before i get this figured out! it is for a friend who wont accept money or i would buy them the damn serial. i have to do this without costing any money.
i intend to use img burn to burn my disc-should it be a R+? i know you like super, but it almost killed my pc and i had to delete it, so that is not an option.
originally i was using freez (i think) to convert until it ran out on me and i have some logs that will tell you what kind of youtube videofiles i have to work with. that program was unable to convert almost all the files. anyconverter is able to convert them all, and i have no idea why.
i have the dvd flick files for ts_video and ts_audio and the audio folder is empty...??? forgot how i got them. i have been working on this for a couple of months now. i have started making extensive notes.
i have an error log from imgburn when i tried to burn one of the converted files. i have a log from dvd flick on something or other i am not sure. let me know how much you can use.
this is my first attempt at doing anything other than a music cd or backup data disc. i know the words mux, bitrate, etc but have no idea what they are. i dont know if i need to make an ISO file or not. i realize i must have asked ten questions on this one thread. should i give it up?
salima
newbie Q about cutting data from flv
By edurbrow in forum Newbie / General discussionsReplies: 5Last Post: 11th Jun 2011, 20:09 -
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 13:39 -
Riva makes my FLV's bigger + can I use VirtualDub to create FLV's?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 13th Jan 2010, 14:53 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 23:09 -
What's the best FLV converter + best method to create FLV's from pure video
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 20:23
