Is there any way that I can place a picture (bmp or something like that) on top of a motion menu?
I want my motion menu still to work (the menu is encoded as a .vob).
Thanks in advance
Not without re-encoding the video with the bitmap in it. If it was just a simple sub-picture - i.e. black and white or white and transparent - then you might be able to do it. But to put a bitmap over a motion menu video means re-encoding the entire video.
Read my blog here.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 16:45 -
Motion Menu's - Where Do I Start? In Photoshop?
By EViS in forum Authoring (DVD)Replies: 11Last Post: 21st Aug 2008, 23:35 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
Motion Menu with custom clips?
By chaosnovaxz in forum Authoring (DVD)Replies: 16Last Post: 14th Jan 2008, 11:49
