I downloaded a VCD Bin/Cue format and I'm getting an "Illegal Function" popup when I try to view the CD!
Burned it with CDRWin 4.0A. I'm running Windows 2000 and have the SCSI1HLP.VXD file in the correct IOSUBSYS Folder.
The CD Image is good because I was able to view the movie after I mounted the Image using DAEMON Tools.
Has anyone seen this before or know what I need to do?
Results 1 to 1 of 1
FFDSHOW won't install on Win2k
By DanielF in forum Software PlayingReplies: 7Last Post: 27th Apr 2013, 06:12 -
Does WinXP fix a known Win2k problem?
By bevills1 in forum ComputerReplies: 6Last Post: 1st Mar 2009, 00:34 -
Win2K hangs during booting... :-(
By spiffy in forum ComputerReplies: 3Last Post: 9th Apr 2008, 14:23 -
windows explorer in win2K
By fjmr in forum ComputerReplies: 10Last Post: 4th Oct 2007, 18:37 -
What does win2K need for WinMediaPlayer9 to work ?
By DBenz in forum Software PlayingReplies: 2Last Post: 1st Sep 2007, 12:21
