Is there any difference visually between x264 q21 and x264 2pass?
It depends on the bitrate or filesize you set for the 2-pass. If you make the 2-pass version come out to be the same size as the 1-pass Q21 (with other factors such as filtering, resolution, audio bitrate, etc. the same), then you shouldn't be able to tell the difference. Some might argue, though (and I'm one of them), that a Q encode will have slightly better quality than a 2-pass encode for the same size.
XviD4PSP Re-Encoding Error?
By Kid Boruto in forum Video ConversionReplies: 1Last Post: 26th Apr 2011, 04:07 -
x264.exe crash in xvid4psp
By hasteroth in forum Video ConversionReplies: 2Last Post: 30th Dec 2010, 16:58 -
Xvid4PSP not encoding
By dontpwnmebro in forum Video ConversionReplies: 1Last Post: 21st Mar 2010, 03:57 -
Error message with XviD4PSP - encoding .TS to X264 MKV
By Phat J in forum Video ConversionReplies: 2Last Post: 9th Sep 2008, 23:51 -
x264 Error when encodingin Xvid4PSP
By torbenmp in forum Video ConversionReplies: 2Last Post: 1st Oct 2007, 15:25
