I seem to have some off-the-air video restoration problems different from the ones most often discussed here:
1. Most of my tapes have the same reception problem in the picture: In a wide band up and down the left edge, it's brighter than the rest of the picture. Cropping this is really not an option. What software would allow me to adjust only this area, instead of the whole picture, as iMovie is supposed to? So far, what I've found is intended for production and so it's much more powerful than I'll ever need, and maybe more complicated to use, too .
2. In some broadcasts, the music pitch wobbled, as though the audio had been through an audio-cassette recorder needing maintenance. What automatic pitch-correction application would take care of this?
3. Some videos turn up with the audio and video out of sync by as much as a second or two. Suggestions for correction tools? At least the interval is constant, unlike 2.
4. Hum buzz might not be absolutely steady in pitch, either. (Luckily, it's not on the videos with problem 2.) Comb filters are supposed to take out the overtones or harmonics of the hum, but what filter tracks small variations in hum frequency (for example, due to slightly unsteady camera speed)?
I'm planning a new computer system to deal with these problems (as well as for the common applications), and I lean strongly toward a Mac, although with an Intel Mac, I think I could run a Windows application as a fall-back possibility.
Any comments and suggestions on any of this would be appreciated. Thanks.
Results 1 to 1 of 1
How do I correct out of sync audio using Fraps, or avoid it
By Didz in forum Capturing and VCRReplies: 3Last Post: 10th Sep 2011, 13:42 -
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 22:56 -
audio sound wobbly with current computer
By bandcamp in forum Capturing and VCRReplies: 6Last Post: 3rd Sep 2009, 16:27 -
Correct Out of Sync Audio in DV-AVI Type 2
By Atariwarrior in forum Video ConversionReplies: 15Last Post: 6th Mar 2009, 19:24 -
Having Issues with Audio Sync when merging part 1 & 2
By DVDNewb in forum Newbie / General discussionsReplies: 8Last Post: 22nd Mar 2008, 03:00
