    Jul 2007
    Think this is in the right place. Basically i have 13 MPEG-2 files with AC3 audio, and they all have varying audio delay values. I want to join them all to one file. What is the easiest way to do it so that the video and audio stays in sync throughout?
    Thanks.
  2. Member Soopafresh's Avatar
    Jan 2004
    Run each file through quickstreamfix in VideoRedo. Audio should be corrected.
    Jul 2007
    Yeah that worked, thanks. Just curious, what is VideoReDo removing from the video files? Whenever i use quickstream fix the output is always two or three MB smaller, but it's still the same video and everything. What is it removing?
    Thanks.
    Nov 2002
    No free alternative and will this work with MPEG2 Program Streams?
  5. Member Soopafresh's Avatar
    Jan 2004
    Thanks.
    My guess is that it's remuxing the audio and video, using a slightly different method to do so.
    Dunno for sure. VideoRedo is one of the few pieces of vid software I've ever paid for. There just isn't a piece of freeware that's equivalent. Program Streams - I believe so.
    Jul 2007
    EDITED. Nevermind, problem completely solved now, thanks.
  7. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    I suspect that it doesn't remux (since it even can't import elementary streams) but drops frames where it finds no audio and drops audio without video for keeping sync at joining (this was discussed here a year or 2 ago). So I always prefer to demux files and put them to Womble timeline with original delays (it can fill gaps with silence/blackness).
