I have a panasonic A120 DVD/VCD player. I have followed burning guidelines exactly. Every time I try and play a VCD it says no disc or no play. I tried it first with a CD-R and it said no disc. Then i read that this certain player works with CD-RW, so I tried it. When I used a CD-RW it said no play. Someone please tell me whatz goin' on! I've also tried the CD-R one in my friends DVD/VCD player and it said no disc. I didn't note what type of player his was though.
Any help is appreciated. THANX
try making a short file using nero's encoder on a cdrw. i find it's a good way to test the system and see if there's was somethig wrong in what you were doing rather than the simply not accepting your disks (or you might want to try a commercial vcd...)
Hi!
Quick point ...... if you check the DVD Players compatibility guide (link on the left navbar <<---), then you'll see that the A120 doesn't accept CDR but does like CDRW .... strange but true!
Also, the make of CDRW could be important too. Try a 2 or 3 different makes such as Verbaitam, TDK, Sony etc etc.
Finally, as Resnullius stated, try a commercial VCD ..... if that fails, take the unit back to the shop!
Hope you sort it out!
Sue xxx
Crazy Car
By budwzr in forum Off topicReplies: 0Last Post: 18th Nov 2011, 12:31 -
Fans are crazy!!
By alintatoc in forum ComputerReplies: 19Last Post: 4th Jul 2009, 05:13 -
Help, I think I am going crazy
By pfxz in forum Off topicReplies: 6Last Post: 3rd Aug 2008, 09:17 -
Hi all, Whats the go with my camera goin gdark when spotlights are on?
By apples017 in forum Newbie / General discussionsReplies: 3Last Post: 11th Jun 2008, 14:41 -
going crazy with editors
By ellabbs in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2008, 11:06
