I have Kaspersky Anti-Virus 8 and today I had a look in 'detected Threats' and found things I don't understand, do I just leave them or do something about them? It shows a green circle with 'no active threats' as soon as you open Kaspersky so I know im not in trouble.
For the 'riskware' I installed a USB network adapter around that time because my laptops inbuilt Wi-Fi died for some reason so I think that might be that but why is it showing as suspicious?
I have no idea what the 'very dangerous' thing is.
help please
right click>go to description opens these 2 pages
http://www.viruslist.com/en/advisories/28083
http://www.viruslist.com/en/advisories/31010
Its telling you to update your software i.e java and flash player if you read through the links that you posted under the heading on the left hand side "SOLUTION" it gives you a link to updated software to cure the weakness in your system.
Install the updates and rescan the warnings should be gone. -
yeah I have java update telleing me to update all the time but didnt know it was that.
thanks -
Same thing happened to me. Following the updates, everything settled down. KAV/KIS is good stuff !
AVIRA antivirus any good?
By wulf109 in forum ComputerReplies: 14Last Post: 19th Nov 2012, 07:53 -
Wireshark Antivirus...anyone know how to remove?
By BLSAMPLES in forum ComputerReplies: 26Last Post: 6th Sep 2010, 09:06 -
What antivirus do you use. 07/04/2009
By G)-(OST in forum ComputerReplies: 9Last Post: 6th Apr 2009, 16:50 -
Cannot remove an antivirus
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 8th Dec 2008, 21:07 -
VISTA aNTIVIRUS
By tapal in forum ComputerReplies: 11Last Post: 3rd Jun 2008, 23:10
