When using CCE SP2 v1.00.01.02 what happens when you insert 3 for the number of VBR passes? I've read that you always get one more pass that what you enter with CCE. So entering 3 actually means in reality the program makes 4 passes, and 2 gets you 3 etc.
I've read that there is a significant law of diminishing returns in effect with the number of passes CCE makes and that there really isn't any point in going beyond 3. That being the case, what is the correct number to enter in the program dialog? 2 or 3?
The first pass is usually just to gather compression data for the next 'real' passes. I used 5 passes when I used CCE to encode SVCDs, but 3 actual passes should be more than enough. Probably depends on the quality of your source media and how much compression you are using.
You could always make up a short representative clip of 5 - 10 minutes and experiment with different numbers of passes. That won't take too long.
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 06:20 -
VBR in CCE SP2 creates playback time error leading to no audio
By Albedo in forum Video ConversionReplies: 22Last Post: 11th Jun 2008, 15:23 -
vbr passes in cce 2.70 sp
By DSLGuy in forum Video ConversionReplies: 1Last Post: 19th Feb 2008, 23:33 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 19:47 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 04:46
