i have encoded a 1.7gb .avi with PROCODER 3 into a 5.07 gb .m2v
my question is how do i fit about 7gb of a movie into a 4.7gb dvd+r without any loose of quality?
thanks
You can't. However the best quialty will be retained by encoding correctly in the first place, not oversizing and then trying to get it back.
Use a bitrate calculator to set the encoding bitrates to ensure that your assets fit the first time. Every subsequent encoding will reduce the quality. If you have multiple assets (titles), total up the running time and use that in the calcualtor. There are several good ones listed in the Tools section of this site. I like vcalc for day to day work.
If it were me, I would write this one up to experience, delete the oversized files, and start again.Read my blog here.
You original .avi file already had quality loss.Originally Posted by just
Does that mean you have 2 GB audio?Originally Posted by just
How is that encoded?
For dramas I usually use AC3 at 128k, which is about 1 min/MB.
Even if you double that, a 2-hour movie only has about 500 MB audio.
You'll still need to reencode the video, to about 4GB.
You could try to compress it (MPEG -> MPEG, using eg Rejig) but better results if you use the AVI. -
Use ConvertXtoDVD with your original avi-file.
You will always lose quality reencoding, no matter
what encoding software you use.
21.7GB on a DVD?
By sebrame in forum Authoring (DVD)Replies: 8Last Post: 1st Feb 2010, 15:56 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 04:05 -
How to Fit 3 movies on 1 DVD 4.7GB and keeping high resoultion and quality?
By Virius in forum Authoring (DVD)Replies: 4Last Post: 8th Aug 2009, 15:12 -
Need to compress 5 VOB files to fit in one 4.7GB DVD...
By pmolson in forum Video ConversionReplies: 12Last Post: 20th Oct 2008, 17:52 -
How can I fit more then 3 Videos/181MB Each on a 4.7GB DVD!!
By Tielurr in forum Newbie / General discussionsReplies: 6Last Post: 25th May 2007, 23:25
