I am using AVS Video converter to convert movies from divx format to MPEG to play on a portable device. Currently a 700mb divx movie expands to about 7GB after conversion.
The settings i am using are:
frame size- 640 x 320 (to match my player)
frame rate- 29,97fps
bitrate- 9000
16 bit stereo
48000hz
Can any of these settings be reduced to reduce the file size?
thanks.
Quite simply, your MPEG2 bitrate is to high. How long is the movie? If 2 hours, go with a bitrate of 5200 for a DVD-5.
At that resolution try a bitrate of around 2500 and an audio bitrate of 192. That should get you a file close to your original size (actually just over 800MB). If you don't like the quality, push up the bitrate and live with a bigger file size.
Read my blog here.
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 11:31 -
Mpg : Mpeg video size and bitrate calculation
By Bonie81 in forum ProgrammingReplies: 2Last Post: 21st Jun 2011, 22:38 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
MPEG-2 video quality by file size?
By 3lutz3toe in forum MacReplies: 1Last Post: 27th Jun 2007, 18:17
