    Oct 2008
    Canada
    Greets,
    Creating a dvd using DVDLab Pro 2. Everything seems to go fine. All vids are encoded into dvd compliant mpg's and all that fun stuff. I created this dvd with the root menu having motion buttons. All that works fine. The root menu links to 5 other menus. I can get to those other menu's no problem. However, when I try to click on the video assets contained within it either does nothing, or in some instances plays a full screen of the menu button video.
    When I go back to DVDLab pro and simulate with 'follow links' enabled, it acts as if it would work perfectly.
    Any ideas?
    Have you confirmed in the Navigation view that each of the submenu buttons are linked to the correct video? It's always a good idea with more complex menus to deliberately study your structure in the Navigation view to make sure everything is as you want it to be.
    Oct 2008
    Canada
    Thanks for the response.
    Checking the linking and navigation structure was actually one of the first things I did. I went ahead and checked it again though, just to be sure. Looks good.
    Oct 2008
    Canada
    Ok, I bit the bullet and went and dropped a shat load on Adobe Creative Suite 4. It has a steep learning curve, but is working perfectly. Thanks anyways.
