Hey mates i'd been searching and trying to make nice movie menus with audio , subtitles etc selection but nero doesn't seems fit my requirements be noted that im just freshie into video making junkies hoping u might giving handy guides and what application should be use stuff like that thanks advance for guides..![]()
A lot of people here use the free GUIforDVDAuthor program. It won't work for me because of some DLL conflicts on my PC, but maybe it will work for you.
Your post has nothing to do with BUP and IFO files. A better subject would be "Need help to make menus". -
As for the look of a menu, you can create the background and buttons with any number of imaging software programs, like Photoshop. Then, you would use a good DVD Authoring program to assign DVD navigation commands to your buttons or texts. Give GUIforDVDAuthor a try (it's free under the Tools section of this site). There is a bit of a learning curve, but it is gives you lots of capabilities, and there are some decent guides on using it.
For your video content, you likely need video editing software like Vegas, Premiere, etc. to make the movie before you ever try to author the final DVD.
Good luck. -
Just look in "Tools" ,left side of this page, for an DVD Authoring software, there is quite a few.
Lots of people use TMPGEnc DVD author (TDA), I use DVD Lab Pro very flexible. -
awesome feedback and thanks to all who gave a hand,appreciated it cheerzies!!
How do I make .bup and .ifo files?
By showmi in forum Newbie / General discussionsReplies: 26Last Post: 3rd Apr 2015, 18:00 -
DVDslideshowGUI stopped creating VIDEO_TS. IFO & BUP files
By gobettee in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2012, 14:52 -
Burn - VOB without IFO & BUP files?
By Miss Sherlock in forum Authoring (DVD)Replies: 25Last Post: 24th Aug 2009, 00:20 -
How to play a .vob .bup .ifo files?
By Kinstonian in forum Software PlayingReplies: 12Last Post: 19th Mar 2008, 16:26 -
Padding IFO/BUP files to 32kb in OS X?
By Cyrax9 in forum MacReplies: 3Last Post: 14th Jun 2007, 15:46
