Hi,
I guess this is an experiment really, which I messed around with a while back and now want to play with again.
I've extracted the movie streams from Schindler's List which is a movie split onto 2 DVDs using VobEdit, resulting in 6 files; the 2 MPEG2 movie streams, the 2 AC3 audio, and the 2 subtitle SUP files.
Is it possible to join the video files together, the audio files together, and the subtitle files together, resulting in one file of the complete MPEG2, AC3, and SUP? Then I can re-mux these files using IfoEdit or suchlike.
Any advise would be welcome.
Many thanks.
Just use DVDShrink in Re-author mode and compile both discs...And I would recommend setting output size to DVD-9 8.5GB and burning to DL disc ...
http://www.dvdshrink.info/compilation.php" Who needs Google, my wife knows everything" -
I don't care to look, but I think http://www.doom9.net might have a guide on doing this. It is possible, but it's a fairly complex operation. I know I've seen a guide on this before, but I've never done it.
I used this method once for backing up my Gangs of New York 2-disc set..And yes it worked,but a bit tedious..
http://forum.digital-digest.com/showthread.php?t=60724&highlight=IfoEdit
Much easier with DVDFab Platinum to merge both..." Who needs Google, my wife knows everything"
why does 3D movie shows up in split screen on my 3D TV
By greenmetal in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2011, 04:08 -
How can I split 10 GB divx movie into 4 parts?
By andy99 in forum EditingReplies: 3Last Post: 2nd Oct 2010, 16:05 -
Split movie and subtitles
By andreltr in forum SubtitleReplies: 2Last Post: 18th May 2009, 08:16 -
Can't join this movie that is split and already burned on dvd
By f-zer0 in forum EditingReplies: 3Last Post: 3rd Jan 2008, 21:21 -
hd-movie how to split
By jetli68 in forum EditingReplies: 7Last Post: 14th Aug 2007, 13:33
