The problem is with the settings below i perform a capture and two things happen:
1) when capturing the preview window the video is stretch well beyond 640 and the height is much smaller than 480, stretched and short, and there are 2 vids stacked on top of each other.
2) when i am done capturing, i play the clip in media player and it is stretched and short.
Is that the way it is supposed to be?
then when i compress after my edit stage do i resize or is there something i am doing wrong when i capture.
Also i want to mention that i am capturing standard definition
Huffyuv-2.1.1
Video - Compression {Huffyuv v2.1.1 - CCESP Patch v0.2.5}
Video - Set Custom Format
- Frame Size
-- 640x480
- Data Format
-- YUY2 - YUV 4:2:2 interleaved
Results 1 to 9 of 9
Chris -
The output from HuffYUV should be exactly the same as the input. Something is going wrong somewhere. Use MediaInfo or GSpot to examine your file. What do they say about the frame dimensions, codec, etc?
You said you see "2 vids stacked on top of each other". Are they really on top of each other, or side by side? Is the image otherwise normal? No weird colors, etc? -
That is not normal. The reason I asked if they were stacked vertically or horizontally was because there is an "unfold fields side by side" option in VirtualDub's deinterlace function. I thought you might have been using that.Originally Posted by cnolan011
The vertical stacking could be that capture devices way of handling interlaced video. This could be restored to "normal" by interleaving the two fields. I don't know of a VirtualDub filter that does this though. -
not looking good to me, . . . . crap
Codec ID/Info : Huffman Lossless YUV and RGB formats (with Alpha-channel)
Duration : 1mn 12s
Bit rate : 22.2 Mbps
Width : 640 pixels
Height : 240 pixels
Display aspect ratio : 2.667Thanks
Chris -
You need to figure out why the preview in VirtualDub is wrong before you worry about codecs. Some capture devices only capture 352x240. What are you capturing from?
You should look through what others have to say about the card:
https://www.videohelp.com/capturecards/leadtek-winfast-tv2000-xp-expert/322
You may be able to find generic Conexant drivers that work better with it. Did you get some capture software with it? Does that work?
Lagarith vs HuffYUV, archiving and file size
By HDClown in forum Capturing and VCRReplies: 62Last Post: 30th Jul 2012, 07:08 -
vdub - bad PCM audio capture after fresh install of huffyuv
By wolfdogg in forum Video ConversionReplies: 1Last Post: 11th May 2011, 00:45 -
[FFMPEG] Known problem with "Frame size must be a multiple of 2"
By yamyam in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2009, 12:52 -
Best codec to bring Huffyuv down to size
By galneon in forum Video ConversionReplies: 7Last Post: 25th Feb 2008, 12:30 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 31st Jan 2008, 23:24
