Hi, Does someone know a software to burn a blue ray already?
Thanks a lot Paul Weinstock
https://www.videohelp.com/tools/sections/authoring-bd-hd-dvd
That is a list of about 10 applications for authoring bluray discs.
It appears that nero and ulead and pinnacle all have bluray support in their latest versions - though a plugin may be required.
If your asking for standalone data only burning for bluray I am not sure what applications would cover that.
Check the TOOLS section on the left of the screen for more options <-------Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Just picked up my burner recently but Adobe Premier Elements has worked well so far
blue ray music video's-what can burn to DTS specs?
By sony sac in forum Authoring (Blu-ray)Replies: 7Last Post: 23rd Oct 2010, 22:28 -
Should Sony change the name to "blue-ray" instead of blu-ray
By yoda313 in forum Off topicReplies: 11Last Post: 17th Feb 2009, 14:52 -
How to Burn Home Movies in BLUE RAY quality?
By ozab in forum Authoring (Blu-ray)Replies: 3Last Post: 15th Jan 2009, 10:52 -
Can you burn directly from Sony hdr- sr1 to blue ray disc, How?
By pistol pete in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Mar 2008, 04:49 -
blue ray blue rot
By NICEBUD in forum Latest Video NewsReplies: 5Last Post: 21st Jun 2007, 13:01
