hi everyone, im a newbie but have been fairly successful at capturing avi's and converting them to vcds my problem is with the 4 gb file size limit in win98se, i've been reading about ntfs but not enough on how to format to it, i also saw a buddy use dual boot to win98 and winxp using two partitions, i currently have 2 20 gb partitions on my drive, how can i use the other one for ntfs, any help will be appreciated, thanks in advance
If XP is anything like 2K Pro, then just install it AFTER installing 98 (but you already have 98 installed, so just install XP) and XP should detect 98 and offer to setup a dual boot system automatically.
When installing XP, make sure NOT to install it to the same dir as 98 (to c:\windows for example). Install it to a DIFFERENT directory or you'll be asking for trouble (like c:\winxp or whatever its default is).
As for NTFS, the best you can do with 98 is READ NTFS, and then only with third-party software. You can't write to NTFS (atleast not the full 2TB file size) under 98. If you want to write to NTFS you'll need 2K or XP. -
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
if you have 2 partitions you might want to install xp on the second partiotion and convert that partition to ntsf. you won't be able to see it from win98 but the oposite isnt true. winxp still has alot of holes though so you might consider win2000 with service pack 2.
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 02:06 -
Select boot? Win7 and WinXP?
By RogerTango in forum ComputerReplies: 2Last Post: 30th Oct 2011, 18:51 -
dual-boot systems
By joecass in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2011, 21:01 -
Solid State HD for WinXP Pro / Vista boot installation….
By retroborg in forum ComputerReplies: 2Last Post: 12th Oct 2008, 15:09 -
DVD player w/USB NTFS format?
By usaRaydar in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Nov 2007, 15:12
