When I run the installer "mpegsae.exe" a bunch of programs are created in a temporary folder but the installation does not proceed. When I try to run the Setup.exe program in that folder nothing happens. I am running Windows XP Pro. Is there some problem with Windows XP?
sounds like more of a corrupt install disk, I have xp pro and panasonic installed and ran fine, however i really don't use it as tmgenc is faster and gives better results.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
Need Help Panasonic HDC-HS250P (AVCHD), USB to Windows Media Encoder
By planet_bill in forum Video Streaming DownloadingReplies: 1Last Post: 13th Aug 2009, 15:40 -
Can not install mpeg components
By franks65 in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2008, 10:57 -
can't install FLV Encoder
By pealia in forum ffmpegX general discussionReplies: 2Last Post: 6th Mar 2008, 12:34 -
Which MPEG-2 Decoder to install in new XP SP2 PC.
By mattstan in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2008, 14:16
