ok, basically, i have two clips. one with a tv on it, and another, just a random clip. i wanna use masking to put the clip onto the tv, but i have a few questions still. one, how do i move a masked clip around. not the actual mask, i mean the whole mask including the clip in it. for example, if i were to have a persons head in the mask, and i want to move the mask down so it matches the tv on the other clip, how would i move it and keep the persons head in the clip? and also, if i have a video with 2 dogs on it, how would i make it smaller so the clip will be the size of the tv and both of the dogs will still show up?please help because i really REALLY want to do this. help is greatly appreciated. thank you
ok, thanks, another question about this though. is there any way to just make it wider, rather than making the whole entire size of it change?
i did the event pan and crop thing, then i tracked motion afterward? is that how i do it? it works fine so i think i did it correctly, idk i just want to make it a bit wider, cuz it seems like theres no way to change just how wide it is cause it always makes it wider and longer.
Sony Vegas render template for clip on PC monitor
By mltwitz in forum Authoring (DVD)Replies: 2Last Post: 23rd Aug 2011, 14:17 -
Sony vegas 10 clip wont reverse!!
By Domiel in forum EditingReplies: 21Last Post: 21st Nov 2010, 17:39 -
Need to increase voice and decrease bgm
By WeAreDrift in forum AudioReplies: 16Last Post: 13th Aug 2009, 00:35 -
Sony Vegas 8.0, trouble viewing video clip
By ir0n_ma1den in forum EditingReplies: 8Last Post: 10th Jun 2009, 20:36 -
Increase audio velocity in SONY VEGAS 7.0 and freeze a frame?
By qazwsx16 in forum EditingReplies: 9Last Post: 30th May 2007, 20:35
