I thought I finally had my hear-tearing .mov conversion problem solved by converting it to .avi with Any Video Converter. BUT now everytime I add audio to the new .avi file, FREAKING WMM CRASHES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Is there ANY WAY that a .mov can FREAKING be COVNERTED WITHOUT MAKING ANYTHING CRASH??!?!?!?!?!? GOOD GOD ALMIGHTY!!!!!!!!!!!!!!!!!!!!!!!!!!
Why does it only do this with .avi?!?!?!?!?? Come on!!!!!! I never knew .avi had this much destructive power seriously......I thought it was a completely harmless, malleable file...but it seems I was dead wrong...ughh...and I can't go back to converting it to .wmv again cuz it takes one hour, and .avi conversion takes only 13 minutes........... SCREW U WINDOWS MOVIE MAKER! U make me SICK!!!
Plz help!!!!!!!!!!!!!!!
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Closed Thread
are you importing an uncompressed wav? most editors like uncompressed files
you may need quicktime pro to deal with .mov
you need to describe everything in the utmost detail in your post
this isn't rocket science...it's much more difficult
Here's some info on the certain video I tried to convert that I got from MediaInfo:Originally Posted by zoobie
MediaInfo info on the .mov:
General:
-Format - MPEG-4
-Format Profile - QuickTime
-Codec ID - qt
-Overall bit rate - 2 134 Kbps
Video:
-Format - AVC
-Format profile - Main@L3.1
-Codec ID - avc1
-Bit rate mode - Variable
-Dimensions - 720x480
-Aspect ratio - 4:3
-Frame rate - 29.970 fps
-Resolution - 24 bits
-Scan type - Progressive scan
-Stream size - 98.3 MiB (94%)
Audio:
-Format - AAC
-Format verison - Version 4
-Formay profile - LC
-Codec ID - 40
-Bit rate - 128 Kpbs
-Channels - 2 channels, L and R
-Sampling rate - 48.0 KHz
-Resolution - 16 bits
-Stream size - 6.30 MiB (6%)
When I converted it to a .avi and imported it into WMM, it eventually crashed. But .wmv doesn't do this. Why?? I gotta use .avi cuz it took one hour to convert it to a .wmv, and only 13 minutes to convert to .avi...
PLEASE stop make new topics. Continue in https://forum.videohelp.com/topic358171.html
Studio 14 Crashes when I import HD video.
By FinalGypsy in forum EditingReplies: 2Last Post: 16th Feb 2010, 14:26 -
HD MPEG-2 import; Vegas crashes...Any other programs out there for this?
By karpodiem in forum EditingReplies: 7Last Post: 6th Jul 2009, 12:39 -
need a basic video editing software to import youtube vids. (not wmm)
By jaiyen in forum Video ConversionReplies: 1Last Post: 8th Oct 2007, 21:23 -
By jaiyen in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 8th Oct 2007, 17:59 -
Green wmm clips when I import
By djlenaDOTcom in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 21:57
