I re-author DVDs by adding subtitles in French, as a teaching tool.
I pretty much mastered the workflow, but I still have an occasional problem: sometimes, at some apparently random point in the movie, my subtitles stop showing. Sometimes the subtitles will re-appear if I "rewind" the DVD a bit and play it again.
I'd like to make sure the subtitles "stick" reliably. I am thinking that maybe the safest way would be to burn (or whatever the proper term is) them into the video file, like forced subtitles. I read that this would degrade the end-result, but if the degradation is mild I don't care much.
Here's my work flow:
Breakdown with DVDShrink
Demux with VobEdit
Process subtitles with DVDSubEdit, Subtitle Creator and Subtitle Workwhop.
Remux with Muxman
Reauthor with DVDShrink
I tried AutoGK but didn't get anywhere. (The external subtitle option asked we to install WinRAR, which I did, but that didn't change anything.)
Help?
If you're intending to "burn" or "hardcode" the subs into the XviD or DivX video, you're using the wrong setting. External subs are for subs kept separate from the video, and are compressed to RAR format, hence the requirement for WinRAR. You don't want External Subs. You want to add the subs you created into the video using the CTRL-F8 trick. Here's Baldrick's guide for that:The external subtitle option asked we to install WinRAR, which I did, but that didn't change anything.)
https://forum.videohelp.com/topic316471.html
They have to be in one of the subtitle formats he mentions at the beginning. No SUP files as you might make for DVD. -
Possibly there is some weirdness in the subtitle file.Originally Posted by kapital
For instance, a bad character, formatting command, or overlapping times.
If they are in a text format, for instance, you can check them in Subtitle Workshop with "Tools/Information and errors".
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 18:35 -
How to view files on "empty" 16GB memory stick
By jimdagys in forum ComputerReplies: 15Last Post: 15th Dec 2011, 07:35 -
Media player Classic won't let me "navigate" using mkv files
By FatalX in forum Software PlayingReplies: 0Last Post: 20th Jul 2010, 20:51 -
DVD player won't play entire "avi" file
By hifiguy in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2010, 01:05 -
xvid-AVIs won't play until re-saved in "copy"-mode
By Information in forum Video ConversionReplies: 0Last Post: 5th Dec 2009, 09:03
