Hello All,
I am looking to buy a DVD/VCR combo. Kinda have an eye on the LG RC897T. I have a general
question. If HDTV is digital then how come most of these DVD/VCR combo recorders use regular VHS tapes
instead of D-VHS tapes?
Because they're cheap standard definition DVD/VHS recorders, not expensive high definition D-VHS recorders.
The signal must be getting converted from digital to analog then for it to be recorded to regular vhs tape.
It can't record in HD at all, since both VHS and DVD formats are standard definition only. It downscales video to SD digital (and converts to analog for VHS) when recording. If used as a DVD player, it upscales DVDs to 1080p, when you use HDMI output. However, if you use the composite or S-video out, it plays back in SD analog too.
Commercial DVDs could look pretty good when played with the LG RC897T, but its hard to say whether your home-made ones will. That would depend upon the how good the mpeg encoder in the recorder is, as well as the quality of the source being recorded.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
8 Hour T-160 VHS tape, what are good VCR's for playback?
By daysaf00 in forum Capturing and VCRReplies: 3Last Post: 8th Feb 2012, 12:21 -
What is the exact physical point where recording happens vcr and a tape ?
By arturock in forum Newbie / General discussionsReplies: 5Last Post: 9th Sep 2008, 22:15 -
Recording a NTSC VHS Tape with a PAL DVD Recorder??
By Lanno in forum DVD & Blu-ray RecordersReplies: 10Last Post: 5th Sep 2007, 04:42 -
old VHS tape making vcr heads dirty
By abbymat in forum RestorationReplies: 7Last Post: 16th Aug 2007, 07:33
