    Oct 2008
    France
    hello,
    i'm in trouble again with mencoder...
    how to convert images sequence into another directory?!
    i mean my tga sequence are in D:\directory and my mencoder.exe are into C:\Windows
    i'm using:
    mencoder "mf://*.tga" -mf fps=25 -o gggu2.flv -ovc lavc -of lavf -lavcopts vcodec=flv:vbitrate=400:autoaspect:acodec=mp3:abit rate=56 -vf scale=640:364 -srate 22050 -af lavcresample=22050 -ofps 25
    mencoder "D:\directory\mf://*.tga"... don't work
    mencoder D:\directory\ "mf://*.tga"... don't work
    mencoder "mf://D:\directory\*.tga"... don't work
    tried with // and \ and Aaaargh...
    thaank you very much if you can help!
    Dec 2004
    Triptonia
    indeed it just crashes.
    mencoder is primarily a linux tool.
    it's much to be expected with windows paths.
    the solution is blindingly simple.
    move mencoder into the working directory!!
    or at least call mencoder from the working directory
    c:\windows\mencoder mf://*.tga ...
    "I'll give you five dollars if you let me throw a rock at you"
