Hi guys i really need help in enahncing this video footage...
basically im trying to reduce noise and sharpen ..
i was reading through the forum looking for good methods and came across these msspuds and some sharpen filter.
in doom 9 forum .
but when i use mc spuds noise reduction i get this weired rainbow or halo effect and it doesnt look right.
also the same when i try to sharpen it.
i have added the sample file for you guys to see , 1 is source 2 is denoise and 3 is sharpen. the total file size is 22mb so not much please help. heres the link........http://www.megaupload.com/?d=SO65D9TK
i tried deband and dehalo but still doesnt get rid of it.
heres my script i use for noise reduction
AVISource("C:\Documents and Settings\king\Desktop\New Folder\source.avi")
ConvertToYV12()
import("C:\Program Files\AviSynth 2.5\plugins\MC_Spuds.avs")
import("C:\Program Files\AviSynth 2.5\plugins\LimitedSharpenFaster.avs")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mt_masktools.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\RemoveGrainSSE2.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\deblock.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\FFT3DFilter.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mvtools.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\RemoveDirtSSE2.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\TTempSmooth.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\hqdn3d.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\RepairSSE2.dll")
mc_spuds(frames=2,strength=4)
ttempsmooth()
and heres my settings for sharpen and enhance
ConvertToYV12(interlaced=true)
Import("C:\Program Files\AviSynth 2.5\plugins\DeHalo_alpha.avs")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\aWarpSharp.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\dfttest.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\Deen.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\FFT3dGPU.dll")
deen("a3d",2,2,2)
aWarpSharp(depth=1,blurlevel=1,thresh=0.2,cm=1)
aWarpSharp(depth=1,blurlevel=1,thresh=0.7,cm=1)
DeHalo_Alpha()
fft3dgpu(bt=3,sigma=5,sharpen=3)
Tweak(sat=1.1, bright=0.0, cont=1.1)
i tried both methods but with no luck... also tried limitedsharpenfaster and seesaw but it looks odd on this footage.
if someone can give me a working script example (similar to above) please.
im totally new to this but i have read the forums and still have no luck.
i tried with FastLineDarken() but it doesnt even load its says some code cant remeber now.
so can someone show me a script with best noise reduction and sharpening without forming halos or rainbows or whatever artifact etc..
just a samaple script and ill play around with it, or if you can enahnce this footage and show me the script so in future if i want to do similar things i can look back to that example..
with settings so i know what plugin to load and what avs to import etc.
this would be awesome if someone can make this footage enahnced thanks.
again here the sample im trying to edit http://www.megaupload.com/?d=SO65D9TK
The source is so bad and captured at such a small resolution that any enhancement will be minor at best. My suggestion is just to find the concert on DVD. It must be available, that isn't rare material.
it is rare you cant buy this from shops, is there a way to at least make it less noisy and more sharper?Originally Posted by Soopafresh
Not that rare.
http://video.aol.com/video/billie-jean-live/1366845/?icid=VIDURVMUS01
The problem you have is that you can't get back what wasn't there to begin with.
My favorite noise reduction function for Avisynth is TemporalDegrain , but even that won't help with your footage.
Video Enhancement
By rckowal in forum RestorationReplies: 20Last Post: 13th Dec 2011, 14:54 -
Audio of video enhancement
By ginny02 in forum AudioReplies: 16Last Post: 19th Jun 2010, 15:56 -
Video from N95...enhancement software?
By coolchrisyorkshire in forum EditingReplies: 5Last Post: 1st Nov 2008, 12:38 -
Video Enhancement Software
By lazyturbo in forum Newbie / General discussionsReplies: 6Last Post: 25th Nov 2007, 17:14 -
Video enhancement software
By terryxpress in forum MacReplies: 4Last Post: 30th Aug 2007, 12:37
