Hi All,
This is my first post here and need help changing the background color of my video. The original video has a black background and need to make it transparent so that I can use the file in Flash with my own background.
The video editor that I am using it is Avidemux. Can I change the black background using this or once imported in flash I could do the same.
Please help!
You need a nonlinear editor capable of performing a luminance key. Vegas, Premiere, etc would be better choices than AviDemux. Unfortunately, since black is the color you want to matte out, any dark details in the foreground might also get turned transparent. You'll have to tweak with the threshold to see what you can get. Usually, a chroma-key (greenscreen) image would work better, but I understand you gotta work with what you have.
DVDLab Pro problem, menu background colors change when rendered.
By PSPGamer in forum DVD RippingReplies: 19Last Post: 2nd Mar 2011, 21:42 -
timecode effect - change color/background how
By The Linguist in forum EditingReplies: 7Last Post: 16th Jan 2010, 21:10 -
Question how to change background menu picture on DVD
By jimdagys in forum Authoring (DVD)Replies: 15Last Post: 8th Dec 2008, 00:55 -
Change from a color to another in a video
By Nokiamania in forum EditingReplies: 4Last Post: 7th Jul 2008, 02:51 -
CSS/HTML background image/color code help
By lordsmurf in forum ComputerReplies: 2Last Post: 26th Sep 2007, 20:29
