Results 1 to 9 of 9
    Oct 2008
    Australia
    anybody knows what program can cut out a scene from dvd and convert it into .avi or .mpg or anything like that? __________________
    I need to cut out one fight from a DVD I purchased
    DVD Shrink in then reauthoring mode. I made a guide just for you, https://forum.videohelp.com/topic358361.html
    Oct 2008
    Australia
    thank you very much
    that was very helpful
    Oct 2008
    You can also use Handbrake
  5. Does the method described above
    (https://forum.videohelp.com/topic358361.html)
    preserve subtitle timing after you cut out a segment of the movie?
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you keep the subtitles in DVD Shrink then yes, it does.
    Read my blog here.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    How do you cut in handbrake? You can choose titles and chapter to chapter but not custom cutting or?
  8. I noticed with DVD Shrink, when you cut out a piece of a movie, then you are stuck with 2 titles (the part before and after the cut). Is there a way to have the movie remain as one title? Or use another software to combine the 2 titles back to one title?
  9. You can try Mpg2Cut2 - https://www.videohelp.com/tools/Mpg2Cut2
    Cuts with original bitrate and saves into .mpg files
