We are using win xp pro service pack 3.
All the windows sounds have suddenly disappeared-from the welcome sound, the beeps, and the signoff sound.
We have googled and yahood but found nothing specific for this problem. How can we restore the sounds?
Results 1 to 11 of 11
Go to Control Panel->Sounds and Audio Devices then select the Sounds tab.
If that doesn't work then go to the Audio tab and adjust the volume. -
Thanks for the quick reply. There are no sounds at all. The usual list of sounds is blank.
in the sounds tab/sound schemes, if you click the down arrow next to "no sounds" is windows default listed? if so select it.
aedipuss: I tried that. There are no sounds indicated. Is there any way to copy from another computer that does have all the default sounds?
I had the same problem on a vista laptop after SP1. I had to go to device manager uninstall the audio device and then restart and let windows reinstall the audio device. after that the audio worked again.
ladyb1998: When you say to uninstall the audio device do you mean the sound card itself? Souns from other programs like games play just fine. Only the windows sounds are missing.
here are the registry settings for the default sounds. check it over with notepad and if you want to install them double click on the file or right click open with registry editor.
restoresounds.reg--
aedipuss: Thanks for the restoresound.reg. It solved my problem. I now have all the old familiar sounds.
System Restore
By tcory in forum ComputerReplies: 10Last Post: 21st Dec 2010, 02:13 -
Can't restore win7 backup image from server with win7 image restore.
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 14th Dec 2010, 18:56 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 22:51 -
Can't restore HP Laptop
By Gritz in forum ComputerReplies: 12Last Post: 1st Nov 2007, 21:46
