    Jun 2007
    Netherlands
    I am having some problem, i have a new system when i try to play avi or vob files, i notice some pixel problem and slow picture motion than the previous system. Few moments ago i decoded own dvd and try to play the decoded file, but same problem.
    do you think, i need some codec ?
    thanks.
    Try first play with vlc media player, it has builtin codecs. If it would work fine then you probably have some crappy codecs installed. Try use ffdshow. If no difference then it might be vidoe overlay / hardware acceleration problem.
    Jun 2007
    Netherlands
    I tried with vlc, its play fine, but question is, it is new machine i did not install any codecs yet. how can i remove overlay/hardware accelertion problem?
  4. Mod Neophyte redwudz's Avatar
    USA
    Hardware acceleration/overlay are settings. I would try installing ffdshow and that may be all you need. Usually overlay problems show as a black screen when a video is playing.
    But poor playback could be related to your video card settings if the problem still exists with the proper codecs installed.
    Might be the video/graphics card drivers.
    Jun 2007
    Netherlands
    I did dl ffdshow, it is doing fine now, rigt side in icon tray has two icon appeare when the file start playing. My question is if i try to burn the file in dvd, will the dvd burn witout problem or with problem.
