Results 1 to 20 of 20
    Oct 2008
    Romania
    hey everyone! i am new of this forum but i have a question... i have a Sony HDR-FX7 witch i think you know that captures HDV, so when i try to capture from it to my pc i can't get it in a rezolution bigger then 720 x 480. i am using Corel VideoStudio 12 and Video Editor 8 and none of then offers me rezolutions bigger than 720 x 480. how can a get it in rezolution of 1080 x ...... ? do i need another program ? do i need a HDMI cable ? please help!
    Are you using the usb port to capture? Try instead the firewire/i.link connection.
  3. VLC can capture from HDV camcorders to native MPEG2-TS files, too.
    John Miller
    Oct 2008
    Romania
    i am using the firewire cable not usb ....
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    are you sure the camera isn't set to record in SD? if you use winDV does it transfer the video? if yes then it's recording at 720x480 SD DV.
    Oct 2008
    Romania
    the camera isn't set to sd ... it's set to record 1080 x....
    Oct 2008
    Romania
    i just got a HDMI cable and i tryed to connect it to the pc but it does'n work ..any ideea why ? when i plug the cable in nothyng happends.. when i try to capture with Ulead it says that is not connected or something about some drive...my video board is Sapphire Radeon HD 4870
    If you have an HDMI port on your PC it'll be for video out, not to import video.
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    yonut. you didn't answer all the questions, does winDV work?
    the cam will only transfer over firewire.
    Oct 2008
    Romania
    no is not working, the camera is set to record at 1080x5.... the video board have HDMI adapter ....
  11. Member MozartMan's Avatar
    Jul 2005
    HockeyTown
    yonut,
    You need to connect your FX7 with firewire cable to firewire card on your PC. Use this program: HDVSplit. It is the best program to capture HDV.
    http://strony.aster.pl/paviko/hdvsplit.htm
    Oct 2008
    Romania
    yes mozartman i am using a firewire cable pluged in the firewire card on my pc but is not giveing me more than 720 x 480. the HDMI cable doesn't work....
  13. Member MozartMan's Avatar
    Jul 2005
    HockeyTown
    Go to the settings menu in your FX7 and see if it is setup to convert HDV to DV for firewire output.
    Oct 2008
    Romania
    i don't want to get it in DV format .. i want to get in HDV but in high rezolution
    Jan 2007
    Republic of Texas
    Yonut, MozartMan knows you want HDV (i.e. high definition), but was asking if your FX7 was unintentionally set for DV (standard definition) output. Did you check it? Also, did you try capturing with HDVSplit?
  16. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    The HDR-FX7 can:
    Record 720x480i DV and output 720x480i DV. Use WinDV to capture.
    Record 1440x1080i HDV and output 720x480i DV. Use WinDV to capture.
    Record 1440x1080i HDV and output 1440x1080i HDV. Use HDVSplit to capture.
    Find camcorder settings instructions in your manual.
    Corel VideoStudio 12 does not support HDV. You need Corel VideoStudio Pro X2 or Corel VideoStudio 11 Plus.
    http://www.corel.com/servlet/Satellite/us/en/Product/1175714228541#versionTabview=tab0&tabview=tab0
    http://www.kiva.org/about
    Oct 2008
    Romania
    the camera is set to record HDV iv'ed chcked and rechecked. i will try Corel VideoStudio Pro X2 to see if it's working.
  18. Member
    Oct 2008
    Romania
    but how about Video Editor 8 ? does it suport HDV ?
  19. Member edDV's Avatar
    Mar 2004
    So what? That has nothing to do with transfer which can be set to DV or HDV.
    If set to HDV camera mode and set HDV transfer mode it won't transfer as DV unless its malfunctioning. Call Sony Service.
    Jan 2007
    Republic of Texas
    Mozartman, edDV, and myself have tried to address the issue of the camcorder's menu setting for the firewire output to the computer -- NOT the record mode! (There is a difference.) There is also a question about capture, especially with VideoStudio, which it looks like you may be starting to address. But you never once said whether you tried HDVSplit or not.
    I'm sorry, but it gets frustrating posting and re-posting the same advice and having it misunderstood, ignored, or debated. It's like talking to a brick wall.
